For the record (or FAQ section), 1980 and older Saginaw pumps have a 5/8" inverted flare fitting on the power hose, return side can be simple hose and clamp (no pressure). 1981 and newer pumps use a 16mm O-ring fitting on the pressure hose, and simple hose and clamp on the return hose. Gear boxes get into an array of fitting choices depending upon 1980 older/newer Saginaw, or Toyota Pickup, or FJ60. PM me if you need to know what these are!!!
