Sag and OverHeat
Orlando, Fl
i have two problems with my cruiser, the back springs sag, and the truck has a tendency to over heat if kept going over 60 for more than like 5 min.
what are some fixes to these that dont require a new suspension or radiatior... cause everything is stock.
What is the condition of your radiator cap?
Where is your timing set?
Sag? Welcome to the world of a 35+ year old truck....new parts pal.
Good luck!
-Steve
timing is set to the original setting, and my radiator cap is pretty crappy
Overheating: Mine did exactly the same thing. Turns out the thermostat was not properly installed--the rubber top gasket had been omitted.
i have a new thermostat, and rubber gasket, but ill see if i can get a replacement cap for my radiator, should i do a Rad. flush or is that just something that wastes your money
Depends on the condition of your cooling system.....if it is full of corrosion, this will restrict the flow of coolant and could be to blame, but I would change the cap first, as it is the least expensive....
Good luck!
-Steve
question: when you move your axel under the spring (SUA) they say you ahve to cut and turn, what is being cut and turned?
It is a SOA, spring over axle, and they are talking about cutting and turning the knuckles to get an acceptable castor angle again and help with driveshaft angles....
Do a search under Trollhole, he has a pretty big thread on this topic out here...
Good luck!
-Steve
i got a new rad. cap, i flushed out the system, and put new coolant in it, a little more water than coolant, but not much more. should the top of the radiator be hot to the touch, is that ok?
I know that others have hit the key basics to look at (therma, cap, flush, etc.), but after doing all of that, I had some surprisingly great luck with this product http://www.redlineoil.com/products_coolant.asp found a lot of feedback on it and research - and I know you do not want to replace the radi if you do not have to - so you might try it (cheap cost as well). BTW, where you live (FL), a 'little more water' in your mix is better from the research I did and what this product claims.
After I flushed the system and replaced the thermostat and cap I was still having overheating issues. I learned from one of the threads that I needed to "burp" the system. Have the cruiser's front end up at an angle and, with the radiator cap off, start the engine and rev it up several times. This allows any trapped air to work through the system. It did the trick for me! Good luck to ya.
Oh, and it's worth mentioning to wait til the engine cools off a bit before removing the radiator cap!
awesome, im gonna try that water wetter tomorrow, and burp my water system, and then im off for an hour ride on the highway and lots of offroading after, so hopefully it all works out
