Now that I have the hole saw coming can anyone point me in the right direction for the template?
Clint
Clint
Clint
ChadElbert, I'm sorting this one out right now. The snorkel hose runs directly into the round opening on the right side of the air filter box. I cut the opening flush and there's a small amount of clearance for the hose to slide through. I want to make this fitting air/ water tight but still have it be easily pulled apart for service if I need to remove the filter box. I figured that I'd simply order a large rubber grommet but turns out that might be a little pricey. I'm heading over the plumbing department this morning to see what I can dream up. I will put up some pictures as soon as I get the job done.
Mounted on the engine with a diesel 60 airbox.
Good luck
Britklr,
Is that a B/H 60 series diesel air cleaner that bolts up on the fender?
Good luck
Do you happen to have any more pics documenting the modification of that air intake? that looks really sweet.
