rusted heater line help
central Fl
ok heres the deal my lower heater lines (rusted through) under the passengers floorboard i was able to replace. the ones behind the engine extending down seem to be non replaceable due to access. has anyone here ben able to find a way to replace them ? what are my options.
options are run 5/8" rubber heater hose and leave the rusted lines there.
lift the body or lower the transmission to get enough room to replace the lines.
or bypass the rear heater. you live in central Florida!
haha yeh its 97 degrees here with 96% himidity with out rain...but im an oem freak i like it as it was designed.. so are you saying run heater hose from the engine bay to the bottom under the floor boards and connect there..in place of the oem metal lines.?
I have rubber hoses running from engine bay back replacing the hard lines
My vote for Florida would be to bypass
But I need the rear heater in Maine when I have my kids in the back in the winter
John
John
How much length did you need to do this?
colorado40 you replaced them with oem metal lines or rubber heater hose? i have new cond. oem metal lines from a parts truck, if its possible to swap with out major work.
Dominic, I have 5/8 gates hose if you decide to go that route. Just call I'll help you if I can!
I don't remember as it has been a few years
I have it in my records somewhere but am away at the moment
Sorry
John
Seriously, if you're in FL I'd say bypass. And I'm an OEM OCD fool too.
what is needed for the bypass.. suppose i could try it and if its not sufficiently heating the truck this winter in NC. during X-mas vacation... go from there.
