Rust repair advice needed
Cary, NC
I am renting a plasma torch next weekend to cut out the rust! But how should I attack this? Look at these pics and tell me what you would advise.
This is the driver's side floor/firewall. As you can see, I picked a horizontal "good" line on the firewall panel and I am cutting from the transmission side towards the rocker. But the way the sheet metal is spot welded to the cowl, I can't figure out the best way to cut. There is some rust at that seam at the cowl, but I think I can leave a 1/4" lip to weld to. What do you think. Also, is that panel spot welded to the body support channel?
I started cutting on the floorboard towards the transmission just past the floorboard/firewall panel seam and will run the replacement sheet metal to that line and butt weld there. Any input on that?
If any of you have pics of a similar repair it might be really helpful!
More to come on the rear sill/quarters/fender wells.
Thanks!
PS that last pic is taken from the transmission towards the rocker.
All I can say it's going to be hard. Heat is your enemy. I don't know if plazma cutting will make to much heat while cutting but welding on thin panels is a beach. If you heat them up to much it will warp the metal. Tack weld the panels until the whole gap is gone leaving enough time for the panel to cool some.
You can also use a heat sink. There is putty that you put on the surrounding metal to absorb the heat. I know Eastwood sells it (that's where I got mine), but local welding supply shops may have it.
I recently just replaced that exact section on my 71 Cruiser. Check out this link.
http://tinyurl.com/py6oq I used a cut off wheel and a jig saw with a fine tooth bi-metal blade to remove the rused out areas. Also get a 1/8" and 1/4" drill bit to drill out the spot welds or you can spend a few bucks and get the EastWood spot weld cutter.
It helps to use an angle grinder with a coarse wire cup wheel to remove the rust and paint so you can see the spot welds. As always, wear a respirator and eye protection!
I had a local shop bend up the replacement metal very cheap!
Thanks guys!
I was going to post up some rear sill stuff, but I think that Coolerman's web site is enough of a guide along with some other stuff I have found here.
This is my first attempt at any type of metalwork besides a few welds here and there. WISH ME LUCK!
I'll post some before and after once the cutting is done, and then when I get some fresh steel welded in.
Can anyone tell me, is the firewall panel spot welded or seam welded to that support?
