woah bro...take it slow.Rust isn't too bad, but your balls are very dry.
Good to know. Thanksyou don't have to take the knuckles apart to fill the knuckles, there is a fill plug on top of the knuckles that you can top them off with
Check your nuts, lube your shaft, and may your balls be wet!
Good to know. If I'm not mistaken that job costs like a grand? Can't remember if that's at a shop or doing it at home. And I plan on cleaning up the underbelly then hitting it with por 15 along with doing an inner frame coating. Just bought an air compressor to start the job. I really like that last part. Seems easy to remember lol.Pick up parts from Cruiser Outfitters (@cruiseroutfit ) and rebuild your front axle while you're there.
Short term fix if you don't have the funds or time right now is to pump about 1 or 1-1/2 tubes into EACH knuckle based on how dry those look. I use Valvoline Palladium (with 3%+ moly)
You also may want to consider spraying the entire undercarriage, frame, body, etc. with Fluid Film or WoolWax to ward off any further rust.
Kinda ironic. We struggle to fix all our oil leaks, only to find out the bottom rust out, then we spray oil all over it and we get happy again!
About $1500 if you have someone else do it. I think you can get it done with bearings and all for about $600 with your labor.Good to know. If I'm not mistaken that job costs like a grand? Can't remember if that's at a shop or doing it at home. And I plan on cleaning up the underbelly then hitting it with por 15 along with doing an inner frame coating. Just bought an air compressor to start the job. I really like that last part. Seems easy to remember lol.
I've got a trustworthy inspector checking it out for me. I've got a great deal going and if it's superficial, i dont mind breaking it down and painting over it with POR-15. I live in Texas so once it's here and managed, meticulously, I would hope it would be a none-issueTo buy?
Too rusty, don't do it.
Does he have a complete maintenance list/record (written, not just hearsay....)?
At first glance, no issues. It's CA. No rust.
Does it tick, whine, growl, clunk, or ding?
Does he want $2500 for it?
I feel like that should be pinned in the faq. as it has been said so it shall be written
Pick up a needle gun to do the cleaning of the rust before you do the POR-15 or the John Deere Blitz Black primer and topcoat (my personal favorite after using both)
To buy?
Id just hammer it with Fluid film. How is the body looking? If it looks like that underneath your rear quarter panels are probably toast, ask me how I know.
An ugly girl that knows how to wear makeup..Have to remove that rear mud flap to actually be able to tell.
Paint looks to be in good condition. I like how much butter they used to make it shiny. Distract from the real issues underneath...
That's the new Wits End t shirt right there.Check your nuts, lube your shaft, and may your balls be wet!
