Running wrong Oil filter
On the road
Website
www.nextgenoverland.com
Hey folks. The brilliant dealer sold me the wrong filter for my LC. Its the yzzG2. Apparently it's for a 4cyl. The only difference is slightly wider and shorter. I plan on replacing it ASAP but is there any immediate harm in using it for a couple hundred miles? It's installed now and seems to work but dint like having such a small filter.
Some have said to leave it but I run a 9-10k oil rotation using 5w-40 T6 Rotella so need the most filtration as possible.
Thanks
You will be fine
I'd run it a couple thousand miles.
Thanks folks for the help. I just ordered a D3 off Amazon. Sent a nasty email to the president of the dealership. The filter was just the icing. It took them 7 hours to mount a tire and do a 5 tire rotation, would not replace an oring on my AC, did not know how to flush my coolant, did not carry moly for my knuckles and could not get my spare back under the car as one link tends to catch. Then charged my $75 for the pleasure of wasting my day....
If anyone ever goes to Rockland Maine...Avoid Shedard Toyota. Shepard Toyota: Toyota Dealership serving Thomaston, Warren, Waldboro, ME
Yzzd3 is also a small filter made in Thailand. That's why that are so cheap. This was news to me a month ago. If you want a large filter that was made in Japan you need the 15600-41010. It won't be cheap.
@beno has them in stock.
After nearly being run off this forum for using a Napa filter, I got a case of 10 of the D3's for less than $5 each.
How not cheap will it be? So far there hasn't been too much cheap stuff I could find for my 80.
As the saying goes, "if you have to ask....."
True enough. I figure 5-6x the cost of the Thailand made unit would be in the ballpark? I think I paid just under $5 each for my non-Japanese filters.
At that point, it's probably just cheaper to change your oil every 1000 miles. How bad can the Thailand filters be if Toyota sells them?
Correct. The Thai filter is fine and is quite adequate according to Toyota engineers.
I just prefer Japanese parts on my Japanese truck.
There is probably some sort of lewd cultural joke in there somewhere but I am way too white to go searching for it with any hope of it coming out right. ;)
That said, that is about what I thought. I change oil more than I have to and I was concerned about the first little filter I put on, but from everything I have read, there is no real reason to worry. As long as Mr. T says it's OK, I say it's OK. :)
Motorcraft FL1A and be done with it, available everywhere.
Heresy, I know. The thought of a non-Japanese item on a Land Cruiser. ;)
I'm at just about 300K miles on my rig and these work just fine.
The Bosch unit is big too. Rockauto had a sale last year where they were less than $3 a pop. I bought two, but now I have 5 of the new unit Toyota sells.
I am more concerned about my oil weight than I am about the filter. I got a little chain rattle this past winter with the thick oil and when I leave the truck for a few weeks. Maybe some lighter stuff might be better for the colder months?
They seem to range from the high twenty' to low thirty's $$$.
I found a single unit sale on eBay recently for $1795 plus $7 shipping. The filter box appeared to ancient and was tattered but the filter was unscathed and still had the selophane seal on it so bought it.
Thanks for all the info!! I run 9k between changes on average and drive my cruiser all over the country at 215k. It's amazing how little it burns and how clean the oil is when i drain it. Just sent it for an analysis...should be interesting.
