running rough
first thing i need to do is check the timing. what's the tachometer thing in the FSM that is hooked up to the battery and ignition coil? is this just for convenience (to view the tach level without looking at the dash)? Although i will have to tackle the head...someone's told me that the white stuff may be from the last job done and might not indicate that mine is bad now.
I've got a timing light and a compression gauge coming from a buddy in the morning. Is there a way to check without a light if the timing is the case?
sorry for all the lame questions I am new.
Timing well not help you.
Second the suggestion for a used 2f, Put in the used one pull yours out and tinker till your hearts content. Get to know the motor currently in the truck. Once you are done building it you can re install in the truck.
Take Jim up on the offer for a pressure test and make sure of what you are up against. I like the thought of the 3fe in a 4 speed 60 though...... hmmmm.
Dave
yes, but swapping the wiring harness over might be a chore. There is a fj60 here locally for sale w/ a bad motor and I though it would be cool to swap my motor from my fj62 into to, 160,xxxx, but they want 2k for the 60 and it would be a lot of work.
But with proper planning, You could do it in a weekend, With some help.
P.S. I know some guys who might be tempted to help.
P.P.S. I can borrow a cherry picker if you need a garage up here.
Dave
If you have a spot down in cbus I will head down if you need a hand, I have never swapped an engine before but I would be more than happy to help out.
Dave
I can be there.
Jim, the truck is on Northwest Blvd. near Grandview. In Between Grandview and Upper Arlington.
I got some bidness tomorrow (Thurs) evening in downtown C-bus. I could be in Grandview around 5PM, shouldn't need more than a 1/2hr.
Call or email me to confirm.
Don't PM me. Too much of that to wade through already.
I took it to Tom & Jerry's on Kenny this morning to have them check it out because my wife is getting ansy without a car...i'll keep you posted. they might just right it off as a POS and diagnose the things i told them to ignore like the rear main and such.
Has Jim stopped by to see it yet? I would not have any other garage look at it because they would/might see your truck as a money tree and try to milk it. 200k would kill a Ford or Chevy motor. Your is getting long in the tooth but she still has some life in her. Get Jim over to your place to pook around. He did a fantastic top end job on my 77 2F. He knows the parts you need and how to get them cheaper than any other shop. I would be hesitant to look at any other USED motor at this point. You could be opening another can of worms traveling down that route.
FWIW I have pulled and replaced my engine 3 times by myself. I would not recommend it but it can be done. You will need an engine hoist. I am in Hilliard and would lend you mine but righ now it is in Indiana with a 454 big block hanging from it. You can pick one up at Harbor Freight for about $150. If you could nurse it out to Jim's shop, that would probably be your best bet. He is 35 minutes east on 70, just past Kirkersville.
garage says 4 cylinders have 0 compression and 2 the others are fine. Either timing gear or head gasket. They've quoted 12.5 hours on the head so I will pay them for the diagnostics and take it home...i don't know if i am capable of doing the top end myself so i'll probably hit up jim.
:grinpimp:knock jim over the head and steal him for a few hours
