running rough
Columbus, Ohio
Website
eyebrowns.blogspot.com
after it got really cold over the last couple of days, my 60 is running like krap. it is easy to start, but it's rough through the whole power band. Idle is lower than usual, but increases when choked. I think it sits around 700 on the RPM. really low blug blug blug - like it just isn't running 'clean.' I've lost some power it seems, too.
what can make it go from running fine (although loud b/c of exhaust) to running rough, and does the cold have something to do with it? After it warmed into the 30's today it still acted this way.
brian
no not really. just when it got down to 10-15º over the last 4 days or so. I did think early on that maybe i had some water in my tank or something -- maybe bad gas -- but i ran it dry and filled today. I drove 25 miles back from work in Blacklick but it still has the tremors.
Have you checked your plugs wires and etc?
Have you checked anything under the hood recently such as oil, filter anything you may have touched?
Go out now with it dark and start your rig to see if you see any blue sparks under the hood at all?
no blue sparks, cruiser88. i am not a mechanic so maybe i am missing something obvious. sounds like schugga schugga schugga schugga like it's having a hard time staying running, but it doesn't drop down low enough to stall.
oil changed 1000 miles ago, i check the wire boots to make sure they were snug but didn't pull any plugs to look at them. the sound to me isn't like it's missing, but I might not be used to the way that this thing sounds in that state.
could it be something dumb like an exhaust manifold? my exhaust pretty much stops at the cat location anyway.
but there's a severe loss of power.
Really hard to guess what the issue is but the 2 guys close to you that knows 60s (that can look at it to assist you in diagnosing your rig) are fj40 jim(not sure how busy he is) and this fella
https://forum.ih8mud.com/members/phaedrus.html
I cannot come up till after the baby is born:frown: which sucks cause i needs to get out:crybaby::D.
phaedrus will more than likely chime in anyway is he is around.
From the sounds of it ..... just something simple being as it will not die.
it's 'rough' whether the choke is in or out. however, it got kind of bad on my way back from work just now, and i pulled the choke out while sitting in neutral...it came a full 2 inches out and took the RPM's up to 2000. i think the gas pedal actually depressed while i did this. I didn't think the choke could come out that far or raise the RPM's that high.
As it is right now, it will not idle properly and is dying out intermittently whilst idling. I have not checked the sight glass because it was dark when i left today.
seems to have gotten worse over the last couple of days, which worries me.
when ya get a chance just let us know where it sits:)(fuel level that is )
oh - maybe this is important too....
when it turns over, it doesn't just go " wau wau wau wau (start)" it does something like "w-wAHH-W-WAH-WAH-w-wAH (start)" like it's over doing it or something. it's not smooth and normal. it's higher pitched and weird.
Been a while since I have had a 60, but on my old 83 and 85's I think choke all the way out in fast idle was about 1800 RPM's. Listening to your sound bite there the truck does sound horrible. I would guess that you have an intake air leak somewhere or a vacuum leak. I dont think its missing but kind of tough to tell.
That's not a real good thing. How many miles are on the engine? Know any history on it? Listening to the sound bite again you might have the start of a lower end knock:crybaby:
202,900 on the clock. i've got papers on the truck that spell it out from when the last owner had it on (about 1998 on). Pretty normal stuff, nothing too crazy. A carb at one point, a head gasket another, upper engine rebuild, those are about as major as it's had done. it has a known rear main leak.
The starting sound just began with this other issue.
darn it. better start looking for another truck because i don't want to put money into this rust bucket!
Yep intake or a huge vac leak.
Do not hear a knock but need to be really there for that.
Tell ya what when it is cold take some starter fluid and spray around the base of the carb where it meets the intake...and spray .
If the rpm gets higher there is your problem. Also check out your PVC valve it might be stuck closed or something. (pull it out and shake it hell just replace it anyway i am sure its old) anyway that does not cost much at your local Napa or cdan.
Dont stop there check every hose you can for cracks etc.
I will get you a link to help (manual) to help you find and learn your parts (cruiser)
:Dfree. Please post up with any questions.
From the sound of it it does not seem like a big deal.....float level was perfect.. could see it in the film.
thanks for the help guys. i will be dealing with this tomorrow as it's going to be dark in an hour or so.
One more question...i have to drive my daughter to Marysville and this is my only ride. will i be flubbing it up any more by driving it 50 miles round trip?
