My '76 has a rough idle and misses/stumbles at all RPMs. The PO had the engine rebuilt and my guess is some of the ancilliary items were not put back together correctly. For one - they had the feed and return lines reversed - fixed now and I also replaced the fuel filter, etc.
The vacuum line of the distributor is going to the manifold - is this correct? Or should it attach somwhere on the carb?
Also, the only way I could get it to run anywhere near correct without sputtering/backfiring was to rotate the dist. pretty far clockwise. I have read that the dist should be almost parallel to the block - obviously mine is not. This may be in part to the knob on the back of the dist being frozen - I can't move it - It can be pushed in but won't rotate - would this cause the problem?
Any help would be appreciated.
