Running lean
Perth, Western Australia
Okay, need some help.
I’m pretty sure the 2F is running lean, and it’s a problem with my Carb. Sparks are light/white in colour, engine wont idle consistently (the idle solenoid seems okay), varies between 1000 and 650rpm (when it doesn’t stall), and shows some hesitation in acceleration at times. When I place my hand partly over the top of the carb, the idle immediately picks up and engine runs very smooth (some times i have to run with the choke slightly on).
I have checked and re-checked the timing, set the points, checked and adjusted the tappets, replaced the spark plugs, checked the idle mixture, replaced the manifold gasket (exhaust was leaking), squirted wd40 around gaskets with no revving, have replaced the pcv valve (and now it’s the right way up … doh!) and changed all vacuum hoses.
I don’t have a vacuum gauge, but I am starting to wonder if it might be a carb re-build job, rather than a vacuum leak?
I do have some blow-by which might not be helping so I plan on installing a oil catch can –however except for a black sooty exhaust, I have no smoke or oil consumption to suggest a big problem. I shall also check my compression, however the engine is very lively and has lots of power.
The problem has been their as long as I have owned the car, however with careful tuning it becomes less obvious, until we went on our recent long trip where it ran sooooo smoothly at speed, but begin to rough idle. I have changed the fuel filter three times, and the fuel pump, and have also run through some carb cleaner stuff and replaced some of my fuel lines.
Can any one suggest what the prob is?
Should I get my carb re-built?
Cheers!
P.s this may be unrelated, but even with metal lines and a heat guard over the manifold up to the carb, it still is prone to vapour lock on a hot day even when the fuel window appears okay, could this be related?
A black sooty exhaust pipe often comes from a rich mixture, not a lean one.
Sounds like you have vacuum leak(s). Do you use a PCV filter system down there?
Might try a propane torch. With engine idling open the torch valve but don't light the torch. Then run the propane all over, under, and around your intake manifold. Where you're pointing the torch when your engine picks up RPM is where your leak lives. (the carb intake not included - that's a desirable vacuum leak)
Yes my pcv valve sits in a grommet off the side of the engine, a vacuum hose runs from it up to a port on the inlet manifold. My Valve cover hose does not have a pcv valve, and runs streight to the air cleaner.
Propane torch eh.., sounds like good fun! i'll have to purchase one...hehe
If my exhast indicates a rich mix, why are my spark plugs white?
Cheers for the help!
Because they're new?
You don't HAVE to use propane. Acetyline will do the same thing as will most any flammable gas. Whatever is used it's important to be able to control and aim a small amount so that a leak can be located with fair acccuracy.
Okay will find something even if its some aerostart.
Even the old plugs became a white slightly tan colour and were quite crusty. But i take your point and will hunt for an air leak... cheaper than a carb rebuild if thats the problem!
Had a chat with my mechanic today, will be doing the Aerostart thing on the weekend to look for air leaks, however he suggested I might have a sticky valve slide.
To test I am going to get a vacuum gauge and see if it fluctuates in time with that cylinder, which would indicate a valve not closing properly.
To fix the head needs to come off, but first he suggested I get some Redex or Penetrene and try squirting it into the carby. He said this stuff doesn’t burn well, but will help dissolve carbon deposits on the guide. Even better if the engine stalls while I do it the valve should get well coated. Doesn’t always work, but he got a car running on four cylinders back on to six doing it once.
He admonished me that my 2F would probably last longer than me so stop worrying and enjoy it!
Will keep the site informed how i go.
Just a thought, I have been running a product called Flash-Lube to lube my valves... Is there any one that can point me to a better product available in Australia?
Also It has been suggested to me that my plugs may be white if they are starting to introduce ethanol to our fuel... who knows, but i wish they would! It burns cleaner and lifts the octane.
[edit]
I like your mechanic already!:D
Chances are the vacuum guage will tell you what you need to know. Normal range of vacuum at idle should be somewhere between 17-19". Occasionally a well-tuned engine will get more. If it's below 16, or fluctuates, then the lack of sufficient, stable vacuum will affect the carburetor.
Report your findings and others will chime in.
Best
Mark A.
Unless you spend a lot of time idling, the spark plug color will be determined largely by the main jet mixture, so white colour or burned plugs may be more of an indication of improper jet size or partially plugged fuel deliver passage ways.
If there is fuel in the bowl, it is not "vapour lock", so you might describe whatever you are experiencing that you think is vapour lock. Maybe something is intermittently obstructing your main jet.
I wondered about that. I have only noticed the glass window empty once, and that was unusual as we were travelling and the engine just stalled. I put it down to a dirty fuel filter, changed it and have never had it happen again. What I have thought of as vapour lock, is when I travel for some time, stop, then cant start the engine 10min later, and have to pour petrol in the air cleaner or wait for half an hour to get it going again. sorry cant remember at that stage if anything was in the chamber -actually i think it was full!!?.
I have tried a carburettor cleaner and it did seem to help... hence in my original post I was wondering about a re-build.
I suspect i have several problems here, and they have accumulated to the point where I cant ignore them all any more. Plus a long trip like we just did would have stirred things up in the tank a bit... my filter stays clean now, so hopefully everything has been flushed out as i have poured several thousand Litres of fuel through the system in the last couple of months, but done very little idling.
Today, I’m checking for air leaks... so I’ll give you some more feed back in a few hours time
Okay, have just run around with some aerostart... no reving when sprayed on inlet manifold, carb gaskets, linkages and hoses. Will do it again when car is cold to be sure, but its not looking like an air leak.
Have put some stuff the local car shop reccomended into the oil to see if we can free up the valves a little.
At this stage, i'm inclinded to just do it and get the carb re-built, as i think i must have a blockage in the jets, as for the other problem, i'll see what happens, get a vacuum gauge and bite the bullet if needs be get the head torn down and valves sorted.
Will keep the forum posted.. could take a little while but worth doing properly. Never know might go the whole hog try and get my blow by fixed at the same time if its not valve related...
Thanks for all your help guys :beer:
mean while she's still driving strong so i'm off to Wedge Island, then Carnarvon in the next two months
Is this a fuel additive? Fuel additives can cause weird coloration and buildup on the plugs.
when i was having problems with mine i had a buddie who was a experienced mechanic take the carb apart and we found that some moron had done some stuff wrong (i.e. wrong jets and put a spacer plate in UPSIDEDOWN and was blocking my idler jets) .....maybe just taking it apart and cleaning it could solve some problems...just my .02
Best
Mark A.
How much fluctuation are you talking about? I'm curious because my vacuum guage fluctuates very slightly (less than 1 increment). The guages reads 18-19 at idle but there is a slight twitch.
TIA-
Hmm, stalled today towing a car trailer up a steep hill in third. On closer examination fuel window was empty on carb, so I pulled out the fuel filter to examine - and a large piece of cellophane was jammed into its inlet. Must have been floating back and forth in the line for some time acting as a valve and choking the fuel flow during acceleration. Now the cruiser doesn’t surge at idle, though I still think there is some rubbish in the carb. I'm going to flush the tank and lines this weekend, replace the filter and see how I go. May still have to put a kit through the carb. Will report back on how things turn out!
Yes it is an additive, but I have to use it.
They have pulled all the lubrication (lead) out of our fuel in Aus. and its just about the only thing on the market they sell to replace it -All the petrol stations recommend it. If i don’t put it in I’ll cook my valves. I'm not happy about it but what can I do? And yes my spark colour may correspond with the start of its use...
An old timer once told me to put 500ml of diesel in with each tank of fuel, but I’m not sure about that and they have reduced the lube in our diesel too (less sulphur). Others have suggested using some 2stroke oil, but that will foul my plugs. I am one of many people with over 10year old cars affected by this!
Okay, latest update.
Have put a carby re-build through.. the carby
wasn’t too hard everything went back together quite easily (easier than when i did my Kawasaki).
Didn’t find much wrong, but thoroughly cleaned everything out, and replaced all the bits and bobs... found a (i believe) balance jet blocked - this is a small tube between two sections of the carb designed to balance air pressure i am told - so i unblocked it. Also found i had lost (during the re-build i guess) the spring that sits bellow the discharge weight. As it was Christmas and i needed the car i put a pen spring in, which the carby guy has since told me was okay to do... i still intend to order in the right spring and replace it ASAP.
Any how, went back together fine and drives much smoother now, Sparks are a nice tan colour, and exhaust seems slightly lighter in colour.
However still have some funny acceleration and a varying idle once the car is very warm (revs then almost dies continuously).
Today i installed a vacuum gauge. It sits on 16 at slow idle with a very slight fluctuation (less than one unit). I will see but i bet it will fluctuate a lot when the car warms up and sits in traffic.
I believe this means i have a sticky valve... time to get the head re-built???
