running cooler = lights ?
well humid air is less dense, 100% humidity air is 5/8ths the density of 0% humidity air, you can see it in aircraft, the wings produce less lift and the engiens less power, that combines into much longer take off rolls, in humid conditions, temperature also reduces density, as does altitude,
heat capacity is generally related to mass but not always, there is some difference in materials, does water vapor have so much capacity that it can make up for its lack of density?
Yes, water vapor has a very high capacity for heat (one of the highest).
This may be true but as a pilot, I can tell you we're not concerned with humidity as we are with ambient temperature. Hot air provides far less lift. There are times in Phoenix that aircraft can't take off because of the high temperature (super low humidity too). Seriously, I've never heard of humidity being discussed in an aviation environment beyond the chance or rain or fog. I'm sure some of these same principals roll over to engine cooling.
Humid air can absorb more heat more readily than dry air. Dry air will help cool by evaporation better however when it comes to cooling a car evaporation does not help you. The same properties that help a water cooled engine cool better than an air cooled engine help the interface btw radiator fins and damp(humid) air.
I am sure that is clear as mud
Actually, you have it 180 degrees out of phase. Humid air absorbs heat considerably less and takes much longer to heat or cool.
If you have a very low humidity day, the air will warm much faster and your highs will exceed a high humidity day. When the sun drops below the horizon, the temperature will cool quickly because there's little water vapor in the air to retain the heat. Think of a desert. Cold nights, hot days.
Dry air at 25oC and sea level has a heat capacity of 1.0035 J/g/K.
Typical Room air is 1.012 under the same conditions.
Humid air at is generally given a value of 1.025.
It's about Heat capacity
That makes sense because the little droplets of water (to put it simply) will retain heat longer than air without those droplets. However, I'm not sure this applies to a heat transfer system like our trucks. We have a closed system not an open evaporation system. Our radiators don't "sweat".
Like I said the fan clutch fluid is the BIG difference but the JDM fan makes a little diff it temps and a huge difference in AC performance...specially on a black rig.
I question this statement :) Having a pusher fan won't do much for the radiator cooling as far as I can tell. Sure, the A/C condenser will be happier but the air being moved by an electric pusher fan just won't do much for the radiator IMHO.
That's why I said the fan clutch fluid made the BIG difference but the Aux fan made a huge difference in the A/C:hhmm::hhmm::confused:
We are not talking about evaporation...we are talking about how much heat the water filled air can absorb vs. dry air. So water filled air (humidity) can absorb more heat off the fins of the radiator than dry air;)
