running cooler = lights ?
Seattle
Well I just completed a 3 week road trip covering 4300 miles. I noticed on the drove down to arizona My truck got up to 216 which is much hotter then ive ever seen it. I run the blue fan clutch and have some cheaper 6 inch off road lights on the arb. I was towing a pretty loaded m101 trailer. From about mid trip on I was running regularly in the 200s. While in arizona i took my off road lights off to put in a winch i had sitting in the garage. While there i also did a sea foam, new plus, wires, cap, and rotor. I left the lights off since i plan on getting different ones down the road and i dont really need them on right now. On the return drive the temp never got above 204 and the trailer was much more loaded down. I pushed her hard on some of the passes to try and get her up to a higher temp but she never went higher. could this be from removing the lights? would it make that much of a difference?
if the lights were in front of the grill sure but you didn't mention placement of the lights. Airflow across the radiator is important.
I'd imagine it probably was the lights. Together, they are a foot wide, so that takes up a lot of the open radiator space for airflow. That is interesting that it made that big of a difference. If you had the JDM aux fan, it probably wouldn't have gotten that hot.
lights were in front of the grill but i guess i was just amazed at the total difference. I mean i figured maybe 5 or 6 degrees at most but 12 degrees is a huge jump. not to mention the truck cooled down faster on the down hills. May have to re evaluate putting on new lights all together
I doubt that the lights had much to do with it, a couple of locals have done the with/without test and showed little difference. One of the big factors here is the humidity, 115F and 10%, cooling systems struggle, 115F and 40% little issue.
216F is higher than I would want it to run, have you changed the fan clutch fluid?
Put the lights back in and retest.
Seems to me the new plugs/wires/cap/rotor could just as well be the cause of your decreased temps, no? In particular, how old were the plugs? Did you save them? If so, what are the gaps?
Curtis
I did not change the fluid as I wasnt running at all hot before and only changed clutched when it locked up.
I may go back in and drain and change the fluid if i see temps like that again
Curtis
Plus were pretty old i believe prolly about 70k miles on them. I didnt check the gaps as i was in a hurry to get out of town.
I have found it has more to do with ambient temps / humidity. I have found that if it is on the edge that a 2 deg difference in ambient temps can cause a big difference in coolant temps. I would highly recommend changing the clutch fluid as well, but I notice a big difference once I added a pusher fan.
Due to the low pressure behind the lights I don't think it would have much effect..air fills back in behind the lights at any speed.
My dad was having similar "over heating" issues as you with about the same setup and once we changed the clutch fluid and added a pusher fan he has been running cool ever since.
which pusher fan did you add?
JDM from CDan....fits perfect and I hooked it up with after run which has been great and now when I start up in the heat I get instant cold AC. Best thing since sliced bread.
edit maybe I wasnt' very clear about this, sorry.
I have the same fan and I don't notice an engine temperature decrease but it does make the AC cooler when sitting still or off-roading.
Like I said the fan clutch fluid is the BIG difference but the JDM fan makes a little diff it temps and a huge difference in AC performance...specially on a black rig.
I'm just adding thicker fluid. I have had help from ToolRUs on mine and then did my dad's myself...I would highly suggest an Impact screw driver for the screws in the clutch they are #3. I do a quick drain....5min or so and then add about 40-45ml of 30k-50k fluid. This fluid mixes with your stock 3k and lowers the viscosity considerably when doing a quick drain.
That seams backwards to me,
I have to agree. How can humidity make any difference to our engines. They don't use evaporative cooling like our bodies (no heat index when it comes to temperature) Our radiators use heat transfer vs. evaporative cooling. I can't see any way humidity would have an effect.
well humid air is less dense, 100% humidity air is 5/8ths the density of 0% humidity air, you can see it in aircraft, the wings produce less lift and the engiens less power, that combines into much longer take off rolls, in humid conditions, temperature also reduces density, as does altitude,
heat capacity is generally related to mass but not always, there is some difference in materials, does water vapor have so much capacity that it can make up for its lack of density?
Humid air can absorb more heat more readily than dry air. Dry air will help cool by evaporation better however when it comes to cooling a car evaporation does not help you. The same properties that help a water cooled engine cool better than an air cooled engine help the interface btw radiator fins and damp(humid) air.
I am sure that is clear as mud
