So as work slows down for a bit, I am catching up with all the things that need doing with the car... this time it's runaway acceleration. I thought for the longest time it was the throttle cable, but I've replaced it, and it does not seem to be the culprit. Note - the carburator, throttle cable and even the damn accelerator pedal are all brand new. This is a GCC spec 1FZ-F.
Symptoms (all of this is "sometimes", and all of it requires applying the accelerator at least once):
- when under load, the RPMs will increase by themselves, even after the accelerator is released. Sometimes increase and stop, and other times just spool up to the redline. Even on a totally cold engine.
- when this is happening, I feel the gas pedal go limp (so I know I'm about to get a surprise when I clutch in)
- usually, if I emergency kill the ignition, roll to a stop and restart the car, it will be OK (though accelerating may sometimes cause another RPM spike)
- fiddling with the accelerator pedal sometimes helps. I will, for example, shift into 5th so I don't actually accelerate, then hit the gas pedal a few times. That may actually cause it to reduce the RPMs so that at least I'm not redlining.
- when the car works normally, it works perfectly. 800rpm idle without AC, 1000 rpm idle with AC, accelerating and letting go of the accelerator drops back to idle.
- although I do not try this often, I am 99% sure that if I floor the accelerator - especially past the "afterburner" click at the bottom of the pedal - it WILL make the RPMs go crazy.
Today I had a bit of free time on the road so I did two tests: the first time the rpms spiked >2,000, I killed the engine and stopped the car on the side of the road. I checked the throttle cable - there was slack at the carburetor side. I checked the throttle bracket that the cable connects to - it was fully released. So I drove again, and the second time it started spiking, I stopped the car once again, but did NOT turn off the engine. There was once again slack on the cable - more than before - but the throttle did not seem to have returned to the zero position. I tried to make it return - it did not go back - but when I pushed the throttle a bit, it returned and the rpms dropped.
Essentially, I am tempted to say that if I keep acceleration to below about 20-30% of the pedal, I do not experience this issue too severely (but not always. I have had cases where I'll press the accelerator just a touch, and it'll catch and run away), but if I do a rapid acceleration, I am almost guaranteed to have to deal with it.
Would anyone have any advice on what I should debug? Any help welcome.
