Rumble in the Jungle
Little Rock, AR
At 213K miles my LX has developed an audible rumble at specific speeds. As I approach 70 mph the rumble begins. As speed increases the rumble fades away until something like 78 mph where it returns somewhat, and then fades away if I travel faster. It's 98% audible as I don't feel it in the steering wheel nor in my butt. Swaying gently doesn't influence the rumble so I've generally discounted wheel bearings and somewhat the tires. I recently replaced my rear driveshaft with OEM and inspected and lubricated the front shaft, but that didn't change anything. Everything is right-and-tight with the steering components and rear end control arm bushings. Tires are Michelin all season, are a couple of years old, and tread wear is normal. The front wheel bearings were replaced at the last brake service about 10K miles ago. I've begun to think it may be the rear differential but I'm just guessing and I don't like to do that. Thoughts? Experiences?
You can check your rear diff fluid for shavings for piece of mind. Tcase too.
My experience has been tire wear has caused the most odd driving noises.
After having a confab with ChatGPT I'm strongly suspecting that my front spindle roller bearings may well be the culprit. Shamefully, I wasn't aware of them and the need for greasing them. Shame on me. If this fixes the problem then awesome. If not then I will have caught up on some long overdue maintenance. While I'm dirty I will check the xfer case and differential fluid.
Good to know. I've had the front hubs apart a few times and never noticed them. Suspect the cv would be damaged if the bearings are damaged?
Mine damaged the inside tube of the spindle. Pics here.
I replaced my steering knuckle roller bearings and repacked my bearings. Everything in the knuckles is either new, carefully inspected, greased and torqued. No change in the rumble. I'm going to do a little shotguning and replace the front differential bushings and front and rear engine mounts. I know that I could to more diagnosis but I don't mind the work and the parts are very reasonable through Impex, and the car is 23 years old with over 215,000 miles, so why not.
Update: This one was a bit tricky. I noticed a small leak at the inner boot of the passenger side CV axle. There isn't a crack or leak in the boot itself. The leak was coming from the small downward-facing end of the inner boot. Apparently the OEM clamp ring is a bit loose. AI tell me that when I drive my hot car into the car wash the cold splashing water cools down the axle and a vacuum draws in water through the leaky boot. The water then mixes with the axle grease/water and gradually leaks back out of the boot. If this is caught in time then the answer is to simply tighten the clamp to seal up the boot. Unfortunately in my case this has gone on too long and the lack of grease and the addition of the water had degraded the lubrication and damaged the inner "tripod joint". The damaged tripod joint causes my mystery vibration between 60 and 80 mph. A new axle is the only repair at this point. I'm awaiting delivery and will report the results.
good detective work.
