Rumble and vibration coming from 07 GX - SOLVED.
South Florida
Solved: opposite side wheel bearing than I expected was bad.
I have had my 2007 GX for 2-3 months now. it has about 104k on it. I have this low frequency rumble that starts at about 20mph and stays there no matter what speed. over 60-70 I dont hear it much because I think engine noise starts to become more audible. I can feel a vibration (not shaking) in the steering wheel and floorboards. Otherwise the GX is just super quiet inside, on my old car I probably would have never noticed this! I replaced the original tires that had some decent dry rot/cracking on the shoulders thinking this was the issue. I put on some michelin XLT (Costco version of Defenders), but the rumble persisted. When I turn right, the rumble entirely goes away, so I replaced the front right wheel bearing figuring that was the problem (pre-assembled kit with KOYO bearing) but the noise has remained.
I do have a leaking inner boot on the left side, not sure it would be related though. Any ideas on what to do, how to troubleshoot other than throwing parts at it?
Thanks!
Hmm OK, maybe I will get a new seal and throw the Hub I removed over there and see if it fixes anything. (you guys probably think I'm nuts for not just buying another new bearing, but that's OK!)
Dan is correct, turning right loads the left front bearing.
I always replace bearings in pairs. But that is just me.
Solved: It was the left bearing! Thanks for the help @Vlad
@Gavin Dennis replacing both would have saved some frustration and time. I'm sure I will eventually need to replace the 2nd one.
