RUINED!!! seized motor...
California/Florida
My showroom 1993 Toyota Landcruiser over heated yesterday because of a bad thermostate... By the time I saw the needle on red it was to late, the truck was sputtering and blowing white smoke...I immediately pulled over let it cool down, added some water and tried to crank it up... It was frozen and the motor would not turn over...Had to tow it home...
I figured the head gasket is toast or head cracked and the coolant and water filled the combustion chambers which caused a compression freeze up... I have really never gotten into these motors hands on, but here is my plan....
1) To test the motor for major damage, tomarrow I plan to remove all the spark plugs. I expect coolant to drain out...Once the compression and pressure is released the motor should crank...I will keep the spark plugs removed and crank the motor and listen for damage while it cranks...
2) If it turns I plan on removing the heads myself and send them in for inspection, rebuilding and resurfacing... Once I get them back I will reinstall the heads with a new gasket set and then torque down to spec's...
3) Replace the thermostate and hope the car runs like before... Does this all sound like a good idea?
My main question to you guys is how hard is it to remove and reinstall the heads? Never did it before, is there any thing I should look for? Will I need any know any tricks...How hard is it?
Any helpful info would be greatly appreciated.. I am mechanical but never worked on this motor so I am a bit of a rookie on this job.... This is a pick of my dead cruiser...
IF the motor won't turn over as you crank it by hand/wrench you have more than just head gasket issues if the spark plugs are removed... If you hydraulic'ed (sp) you could possibly have bent something like a connecting rod. More than likely you had some sort of galling in the cylinders. You obviously have to pull the head to find out. If you are mechanically competent you can probably swing it. I wouldn't recommend doing this job if you don't have a garage or a free spot in the driveway. Also keep in mind that you might be able to find a good used motor for less than repairs may cost if severe. Don't try it without manuals, haynes at least, factory is best and worht the $$$. Good luck.
Worst case scenario there are a lot of guys like me looking for a sweet deal on a non-running 80 for a diesel conversion...
Oh now aren't you a breath of fresh air. LOL!
If the cylinders are not gauld up and the motor is still seized you could have toasted you main bearing and rod bearing as well. :D
OR it could be just as you suggested. Sounds like you have the right plan, go for it. There's a head gasket DVD available somewhere, IdahoDougs name seems connected somehow IIRC.
-Spike
Thanks for replies fellas... I have considered a 1uz-fe motor swap on this cruiser for over a year now as I also currently own an older modified Lexus SC400 and just love the 1uz-fe motor... My SC400 puts out 300whp and 500 torque on my last dyno... Just a tank of a V8 is the early model stock 1uz-fe's motors...Too much involved with that swap though for me to deal with...Time, money and work space is limited...Stuff I considered - finding the appropriate bell housing adaptor for the swap, instrumention integration, ECU, fabbing motor mounts, etc.... Too much money for truck that is probably only worth 5 or 6 grand when running... That would be a sweet swap though if pulled off...
So I put this cruiser in the papers today for $3000 obo as is but am still going ahead with my fix plan tomarrow.... It's a shame because like I said this truck is perfect condition and won of nicest you will ever see, no dents or dings on the original body and paint, new highflowing exhuast from the stock headers on back which gave it good power even at 4000rpms..Not loud either..., new brakes and rotors D/S front and rear, 4 new Michelin tires, upgraded interior, $500 flip stereo, amp and speakers, new radiator, new rebuilt drive shafts both front and rear, the car was perfect and loaded and ran oh so smoothe even at 90mph and braked well too... It has a K&N filter and intake and the truck produced way more power over stock... Almost tow worthy of a mid size boat...It also has a nice alarm, tint, tow, etc.... It's amost like an old dog you just have to put down.. This has been a daily driver for years and years..
Anyway, thanks again for the replies and I will use a manual for head guidance...I guess it will all depend whether or not I can get the motor to turn over tomarrow after removing the plugs..That will decide whether to keep it or sell it as is...
You know guys, I grew up on all the LandCruisers, my first cruiser was an FJ40 with a Chevy 283 V8 motor swapped in it..Had 35's with Soft Rancho suspension...A true off road beast... Torquey as can be and even twisted the gears with all the torque...Broke off the front spindal and wheel on a jump.. Sold that FJ40 years back to buy a house...Loved that one like I love this one.... My older brother now ownes the FJ100 and that is a big step up from my current cruiser...He loves it...I think it is nice on the inside, but I really like my older body style better...
I may consider the cruiser upgrade if I sell this one.. My only concern is I can see the FJ100 98 Cruisers eat gas up like crazy even more so then the Fj80's.... I dreaded the gas consuption of my FJ80 in stock form. I combated that by lighened it up some and it did ok after the exhaust and intake upgrades were finished.. I removed the third row of seats and stored them in my closet, removed the spare to lighten the load... Installed a wood grain dash kit and steering wheel upgrade....
Sorry for the story just a little bumbed out about this whole situation...All over a bad $10 thermostate too.. You guys would understand if you had a car for 10 years and took pride in it...
Anyway I think I have a pic of the inside of my 93 to show you guys my upgrades... Ebay is great for the little extra's to make the cruiser's look up to date...
theres a 94 motor for sale in the parts section, I believe he is asking a thousand for it, might want to look into it if the body is as sweet as you mention.
I know of a 96 motor with Super Charger for Sale in SoCal. I am not sure how much but PM me if interested and I will get you to the guy selling it. Already has the Headgasket done on it too. I think around 160K miles.
Smit
You guys are great, thanks...
If I do need an engine swap I will probably just sell the dang truck...However, if a really sweet deal came up on a 93 motor I may consider it.... When purchasing a 94 or 96 motor for a swap I will have ECU and wireharness variations when swapping...Transmissions are slightly different as well so the ECU tranny codes may vary... When switching year motors even though they are the same engine and size it's not an exact mate in most every case... I might as well go with a V8 swap if I go for a different year motor...
Thanks anyway, if there is a 93 motor I may be interested...
The long block of the motor should be the same. Head down to oil pan.
Maybe so, but I sure there are some variations some where...Toyota loves to make suttle changes year to year...Example, I remember a few years ago I hauled in from a junk yard a 94 Cruiser tranny for swap into this 93 Cruiser..The swap tranny had 50,000 original miles on it and mine has 150,00m miles... I thought the newer 94 tranny would bolt right up and everything was the same..I was wrong, it was the exact opposite, alot of different variation, so many differences I had to forget the whole idea.....
Needless to say I had to return the 94 tranny and forget the whole swap idea...So I am a little gun shy when switching motor or tranny year swaps in these cruisers unless absolutely proven other wise.....
The trannies changed (in '95), the engines didn't except for the PAIR valve and maybe some sensors. Unless you somehow got a 3FE in your '93.
-Spike
Sounds like you badly overheated the engine and blew the head gasket. Here's what I'd do. Pull the sparkplugs tomorrow and crank it over. I think it is not seized because these are really, really stout motors - most likely just hydro locked. If you can turn it over, spray marine grade engine fogging oil in the sparkplug holes and continue to turn it over until you're confident the engine can now sit with oil in the rings instead of coolant. If you can turn it over, replace the head gasket and drive as normal. Don't underestimate these beasts.
DougM
I don't under estimate these engines...The are huge heavy iron blocks that last forever as long as you don't over heat them... I've seen these motors run past 300,000 miles...
When my cruiser overheated I really think it wasn't that bad of a overheat, but bad enough to fry the head gasket, maybe crack the head at worst, but to have lower engine or cylinder wall and or ring damage would be a suprise to me... If the motor turns today I will remove the head and inspect the rings and combustion chamber, cylinder walls, etc...for damage...
I will be removing the spark plugs in about an hour and try to crank the beast over.. I am confident it will crank... I found a bunch of head gasket sets on Ebay for around $70 for a set, is that good deal?
Question? - WIll I need to use gasket sealer or any kind of silicon sealant when setting in the new gaskets? It's been a while since I worked with heads... I use play around with Chevy heads, port them and what not, but it's been about 10 years or so... I remember years ago I had a 94 loaded Land Cruiser for about 6 months and it used a ton of oil.. I went and had the engine rebuilt for $3000... The thing I remember is that the mechanic whom did the job used alot of gasket sealer everywhere, you could visible see the red gasket sealer petruding from all the heads and block connections... That is why I asked the above question...
I did check the oil out and there is not one drop of water or coolant mixed in with the oil so that is good news... Also there is no oil in the radiator... I am really hoping it is just the head gasket that blew and nothing else... My only concern is a did hear some faint knocking in the motor right before I shut it down and it seized...It also idled horribly as it blew white smoke prior to seizure...I realize that is to be espected when the motor is over heating and the head gasket is blown...
I will report back my finding in an hour or two...
Spike - When comparing the 93 to 94 Cruiser trannies, the wire and connections were all slightly different, the phisical deminsions and bolt patters were identical...It's all the little connetors that were different...
Sounds like you were trying to bolt a '95+ tranny into a '93. They are different trannies, but are used on the same engines in the same vehicles, so all the bolt patterns would have to be the same. The electronics are different though, so they aren't as simple a swap. The '93 and '94 trucks use the same trannies, with the same connections.
I'm not pushing you to put a newer motor in your truck, just trying to explain that it's an option, and your earlier experience shouldn't rule it out. I would rather put a head gasket on my motor then swap in a used motor that I know nothing about. Unless the new motor was free or something. If my motor was completely toast and required a rebuild, a used swap might make more sense.
-Spike
Spike I hear you.....
Ok, I removed the plugs and found the cylinders filled with cooland and water as expected... I drained them all out with paper towels and other absorbing materials...Went to crank it and it turned over effortlessly with no noise from what I could tell....Hoooraahhhh!!!!
So I could be looking at just the head gasket being blown out....Hopefully not a cracked head... Now the fun begins, head removal.... Man this head is long, like three feet...Forgot just how long this 4.5L inline six motor is... The only hard part I can see it getting to the back bolts of the head near the fire wall...Other than that it looks pretty basic...
Thanks for all the replies ... Ordered the gasket set for $60 and going to get a manual now... These engines are very stout, very hard to crack a piston, bend or break a rod , etc... under N/A conditions...
Oh, I also removed the original 1993 factory thermostat, frozen and rusted closed from what I can tell....You guys with the older cruisers may want to change out your original thermostat's just to avoid what just happen to me...
Save your old gasket. Cruiser Dan is collecting them. He is going to make a sculpture or something out all the ones he collects.
I would not use anything other than OEM headgaskets. Too much is at stake and it takes a lot of effort to tear it down.
X 2
CDan's OEM valve grind kit is worth every penny. It's nice to have all the little stuff you need but don't think about.
x3 go with an OEM HG - Just consider the amount of work that you are about to delve into, how long your original OEM HG lasted, and don't skimp here. From what I have read the new OEM HGs are better designed to boot.
I would highly suggest you consider getting the HG DVD from IdahoDoug. There was a recent thread on MUD of a gentlemen that replaced his HG and I believe one of his follow items from his "lessons learned" thread was that he wished he had the DVD or had waited for the DVD. He probably has a lot of good info in that thread you may want to read.
As I understand it you'll also be better off pulling the hood to free up room to work.
Good luck!
