My understanding was that the Ruff Stuff FJ40/60 Diff Cut Spring Perch could be used on a spring under when the diff is close to the frame when spring under.
I talked to one of the guys at RS today and he thought that was the case, but the more I look trying to find someone that used one on a spring under the more I doubt it will work on a spring under.
The plan is/was to mount the Diff Cut Perch on top of housing as if it was going to be a SOA, and put the boxed spring under perch on the bottom of housing and then use one U-bolt and the two bolts.
The boxed spring under under perch will need to be cut to fit the squared part of the diff housing, but it should be a strong set up. I ordered one this morning. So hopefully it will work good.
Has anyone used one or have pics of one on a spring under axle?
Cheers, Allen
Cheers, Allen
