Rubber Flooring
Houston, TX
Where can you find the rubber flooring that is pictured below. How spendy is it??
it looks like the mat i got from www.coolcruisers.com its there aussie floor mat and is around $250.00 + or - but does front and rear and you can get extra insulation from them too its basicaly foil backed insulation pre cut to fit under the mat. over all it was well made with a few imperfections but minor. it sure cut down on the noise and heat inside the cruiser. i believe www.man-a-fre.com sells one too and probably www.sor.com also.
