The Yakama tent Has been installed on the OEM roof rack. It’s about the tallest roof top tent I have ever seen; doesn’t look safe to me. Never seen one install like this and I would appreciate any thoughts as to the safety of this set up.
View attachment 1860638 View attachment 1860639 View attachment 1860640 View attachment 1860641 My wife and I talked about getting a rooftop tent. I tend to be slow to make a decision, usually have to think about it for a few years and have plans as to what I want. She decided to go out and just surprise me at the local sporting good store. Kind of hard to put under the Christmas tree.
I would also recommend going with at least 3 cross bars to help distribute weight.
As for Ops question "Is this safe?", the answer is no. Factory rack is not strong enough to support the weight or hold the tent one the roof going down the road.
I called my RTT maker (Free Spirit) and they said that two is what they recommend. All the RTTs I've seen have their own structure for distributing the weight. No need for more than two crossbars. AFAIK, the cruiser gutter is plenty strong to hold the weight using two bars.
pretty sure the factory rack is rated for about 150 lbs. I personally would be looking to mount the Yakama rack to gutter mounts directly. Remove the factory rack plug the holes with stainless steel bolts and rubber washers to seal them up. She hasn't doubled your life insurances lately?
Awesome gift but your going to need to upgrade to an aftermarket rack. I don’t have the numbers on me with what a stock rack is rated for but no way i’d trust it with an rtt going down the highway....
When I pulled my stock rack you realize how flimsy it is....
That factory rack was rated at 150 new... it won't have that same rated now unless yours is very special and all nutserts have zero compromise.
like others are saying you need a rack that is gutter mounted. Even the cheaper gutter racks at lowes or homedepot for ladders and such would be an upgrade i am sure.
Seems like you have a safety argument and it is up to you how much or what information is included in that decision making process.
If you need it, someone here can tell you that the safest way to carry that tent is a bowfin cruisers rack.
We are here to enable.
Agreed on above. Go with gutter mounts/crossbars, or better yet a Bowfin Cruisers rack.
I have the same tent on a Bowfin rack and it works great. Still a little tall, but not as near as high as thedouble stacked rack system currently on your roof. The way your mounting is set up now has too many potential points of failure. Not to be an alarmist, but if you search old threads enough you come up with stories of RTTs attached to a factory rack separating from the truck at highway speeds. Even the best outcome from that scenario is not a good one.
The Yakima mounting clamps are a slick design and it is great to be able to mount the tent with no tools. The Yakima mounts fit the Bowfin crossbars just fine and I can actually tighten the front mounts easily reaching up through the sunroof.
In the future I plan to just bolt a pair of the Bowfin crossbars directly to the bottom of the tent and leave them there permanently (removing and bypassing the Yakima mount system completely). This will reduce the overall height by a few inches and also improve the strength and stability of the mount. Additionally, the Bowfin crossbars are attached from the side of the truck and so the tent can be attached/removed without ever having to reach under the tent and fiddle in a tight space.
Notes:
- Check the tightness of the Yakima clamp mount bolts to the tent base. You need to remove the mattress and use an Allen wrench from inside the tent. Mine were loose when I bought it pre-assembled.
- If you have any problems, Yakima customer service is top notch. It is a 2 year "bumper to bumper" warranty on their tents. Save your receipt and register through their online process. I had a small manufacturing defect (misaligned grommet) on the fly and they had a new fly on my doorstep with no hassle. I was impressed.
Other than that - Enjoy the tent! Mine has been VERY comfortable, sets up in the dark in less than five/ten minutes, and has proven exceptionally stable and dry in gusty thunderstorms and torrential downpours.
Tent on Bowfin rack.
Yakima clamp rubber insert matches round or square bars (Bowfin bars are square)
[QUOTE="Dubbinchris, post: 12090544, member: 103992 Who ever sold that tent to her obviously sold her the additional Yakima bars that are now clamping to your factory roof rack. They should have sold her the gutter mount version of the Yakima stuff. The 1A gutter mounts are top notch. I have many many years of experience with Yakima roof rack systems.
Edited to add a few pics of my set up. And I do plenty of off-road as well.
