RTH: What plug is this?
Seattle, WA
Creating another thread to keep organized. Broke this connector while taking out alternator. Does it just go back in the round hole? What is this for? Wanna make sure I put it back right. Thanks!
Yep ignition hot if I remember right to the coil. Only one wire through that 3 pin connector. Not sure why they did that.
Interesting that’s what I thought but wanted to make sure. Should be good to just plug it back in there then. Man my trucks plastic connectors suuuuck
The desert kills them, the best way is first push them in then, unplug them, it may take a couple tries
Theyre horrible after some time
Yep. Single wire, yellow with red stripe. Definitely need that one. About the only factory harness wire left in use after my engine swap if that tells you anything.
Shouldn’t just pull out easily like that, so I’d look for a new housing. Should be available. Or save the headache of searching for right part number and repair with a weatherpak/Dephi connector. You’ll need to purchase the crimper. Great tool to have for future wiring projects.
