RTH Upper Control Arm Length?
So Cal Mountains
I'm trying to get rid of the GRRR upon deceleration. I now have front and rear DC driveshafts and the GRRR is still there. (to complicate the matter I didn't notice is before getting regeared to 4:88's)
I had previously tried all manner of adjusting the rear UCA's and am wanting to go back to where it was supposed to be after I first installed the lift.
Looking back at the Slee instructions, I see that he recommends 1/2 " shorter than stock. What is the end to end measurement for the factory UCA?
On a related note, should pointing the pinion down slightly work for the DC rear driveshaft as well, or should I be doing something different?
Thanks in advance
No, I'm not sure. Naturally the guy that set up the gears said it sounded over the phone like U-joints. Since they had about 160K on them I put new ones in. No change, but the GRR changed with a change in pinion angle, leading me to believe that it was the rear drive line angle being too out of whack for the single cardan joint. Now I have my double cardan shaft in, I'm thinking again that it may be the gears. I want to eliminate the possibility that it could be the front.
I'll be ordering a CDL switch tomorrow or Tues so I can run one shaft at a time and narrow it down. I don't feel any play in the front U-joint that I don't think was changed when I had the DC joint put on the front.
I just read that the DC joint should be on the Xfer case, could that be part of my problem? I'm heading down to my garage to turn that thing around. Then I'll come back and see if there is an answer about the UCA length.
Why not pull the DS's one at a time and drive with the center diff locked? If it goes away with one, that'll tell you something.
Pin Head, thanks for the info. I re-installed the new rear CV driveshaft correctly and now the pinion angle makes sense. All I had to do was look at it and should have been able to tell it was backwards. (Now I know what an idiot feels like.)
The upper control arm length is no longer an issue since I just adjusted the pinion to closely match the driveshaft angle.
Unfortunately it still did not solve the main problem of my GRRR when there is no load.
I'll have to try again next weekend after installing a diff lock switch so I can remove the front driveshaft and isolate the problem.
Thanks for the insight Rick.
Does anyone know if phasing can be an issue with a DC driveshaft?
Something else that makes me think it is driveline angle versus the gears, is that it can be induced when going over a bump. When the suspension unloads or the weight shifts to the front, I briefly get the Grrr as well.
Here is what I
How much weight is on that truck? I see you have the Slee 4" springs and if the truck was on the light side you might get into this problem. On the truck that I looked at I suggested that they cut down the springs and drop some of the height they had. They didn't follow my suggestions to the letter but they say there was an improvement from what they did do.
Phasing should not be an issue for DC shafts. Noise on deceleration suggests that something is worn or has excess clearance so that it shifts when you reverse the force on it. Check for slop anywhere that is not rotational backlash.
Rick- My rig is pretty light, but I do have about an additional 80 Lbs on the front with a little bit of a stink bug lift to the unloaded back end. I have had the same problem with it loaded down with 4 people, tools, ice chest and a trailer on the back. It does seem to be louder without the weight than it did loaded down though now that I think about it.
Pin Head- I incorrectly described the noise as being on deceleration. It is more accurate to describe the noise as occurring when the shaft is unloaded, when there is a weight shift from back to front or if I am off the accelerator going downhill and I go over some bumps, I get the noise.
The only movement I can find is backlash, but I'll disconect the front and see if I can find any play in the front joint. Maybe I'll just replace it to eliminate that being the possibility. :meh:
I
