RTH transfer case assembly
I am replacing the rear output shaft seel. I have the rear of the case out, all snaprings out and the large splined shaft out. The large splined shaft was a bit tough to get out. I cracked the PVC fitting I had with a few good sacks getting it out. So my question is about the small 2 inch tube sticking out of the end of the splined shaft. I put a small nich in the side of it and raised a small bur on it. I will check to see if it is still straight and round. I think it is. I can easily remove the nick with a file. But what does this tube do? Does it spin inside anything or is it stationary in relationship to what it inserts into? If parts spin on it I might prefer to have a new one. If it is just a tube to line things up than I have no issue dressing it with a file. Any info would be great!
Can you post some pics?
Sorry but I don't have that ability with my phone. The part I buggered is about 1.5 inch by 1/4 tube. When you pull the rear section of the transfer it way at the end of the splined shaft that attaches to the drive shaft.
I went ahead and just cleaned it up. Worst case it won't shift well and I will pull it back out. Not to bad of a job. On a side note anyone know the torque spec for the 9 bolts holding the rear of the transfer case together? 14 mm bolt into Al. I figure about 25-35 ft/lb maybe?
For reference as I have a leaky rear T-case seal too.
The part time conversion has a good reassembly video once you get past the PT conv part. His grease on the oil pump shims is a good and often over looked tip. Taping the case flush on the reinstall with a hammer before tightening is a good one too.
I rarely have much to add to the forum. So I will say this a easy repair. A few hints that are not covered. Remove all but two or three bolts. Lossen them. There are tabs on not driver and pas side. It tapped them each and broke free the rear section while it was retained by the loose bolts. Then remove the bolts and rear section easily.
When removing the splined shaft see if the little tube i buggered will come out before you start hammering on the shaft. Obviously use wood or a soft hammer bit removing the tube will be one less part to mess up.
Also when putting in the new seel. The old seel was usful to drive in the new one along with a rubber mallet.
