RTH snap ring issue
Oregon
Doing the knuckle rebuild.down to the snap ring on passenger side and I Can't get the axle to pull or enough to get snap ring into groove. So without tearing it all down again Does anyone have a solution to this or am I missing something so obvious? Any help would be appreciated and thanks in advance.
Yep, just fish around the engine bay for a bolt of the right size to screw into the little threaded hole on the end of the axle. Then use that bolt as something to grab on to pull the axle out a little bit.
? 'Do you recall how much room you had from the flange? I'm barely getting the snapi ring past the flange. I put a bolt in the end of the axle and pulled and that's all the further I was able to
