Page 3:
http://www.sleeoffroad.com/installation/slee_lift_kit_80_series.pdf
I had to file all mine as the PO overtightened them. Hope this helps out.
STAINLESS STEEL BRAKE LINES
To avoid overstretching the existing brake lines, install the stainless steel brake lines first. Remove the
existing frame to axle brake lines one at a time and replace with the matching stainless steel line. The
lines are supplied with a small thin washer. The purpose of this washer is to stop the fitting from pulling
through the hard line brackets. Install these washers on the stainless steel fittings before inserting the
fitting into the hard line bracket.
If you have trouble inserting the hard line threaded nuts into the brake line female fittings, inspect the nut
on the hard line. In some cases they were over compressed against the seat in the original fitting. If this
is the case, you might have to use a small file to remove some of the material on the end to ensure that it
inserts easily.
On ’93-’97 vehicles there are two front and one rear line. On ’91-92’ vehicles there are 1 rear and 1 front
line.
Once all the lines have been replaces, bleed the brakes and check for leaks and proper operation of the
brakes.
