RTH - Front Rebuild
Hi everyone, I got done taking off one side and started cleaning the housing. The problem is that the upper trunion is not coming off the bearing cap. How should I proceed? Thanks for the help.
Turn the cap upside down and bolt it to the knuckle then work the bearing off with two flat screw drivers working side to side.
Well I tapped it with a drift and it popped off. I couldn't access the race because the trunion bearing wouldn't come off the bearing cap. What do you think? Should I just get a new upper trunion or is something else fubar'd.
Q
You need to replace the race and trunion. Make sure ther are no divits or gouges when you get it off post pictures if you have questions
While you have it torn down should replace the Trunions on both sides.
I thought you sold your 80?
That is really weird. I never have problem like this. I almost finished my rebuild now. The trunion bearing should just come off easily by finger strength. If it is stuck, something is wrong, you might as well replace it. You should be able to use a brass drift access from the bottom through the lower trunion opening.
Q
Romer: I sold my 93' 80. Then I went into withdrawal and bought a silver 96' LX450 :) I agree that I should replace the bearings, and I have the new ones in hand from CDan. But I want to check with you guys if there is something wrong if the trunion doesn't just slide off the cap.
Ranma: That is exactly what I did. Thanks :)
