RTH. alternator issues?
Oregon
Was experiencing battery drain from lights and other accessories use. Decided to replace alternator brushes and all 3belts while I was in there. Now have battery warning light coming on and experiencing no charge on the dash battery indicator gauge, also lights are dimming at the same time other warning indicator lights coming on dash, ie ABS.
I thought I put everything back the right way, apparently not. Any help on this matter would be greatly appreciated. Thanks in advance
I'm not going to be much help with the alt rebuild question but do you have a multimeter to see what alt is putting out?
I don't at the moment, I will when I return home. Could possibly get one, what do I need to check and how do use to find out if I have an issue
Well it seems it's not outputting enough bolts and it's making your truck unhappy. The multimeter will verify that. Measure from the output post at the alt.
On my way to my folks where I'm working and it died. When I get where I'm going what setting w/o I need to have multi meter set at?
@tlc1995 update your profile with your location. Maybe some one is in the area that can help out.
As previously mentioned, you'll need a multimeter. Set it on 'DC volts'. Black lead to ground, red lead to output lug on alternator. Let us know what it reads. IF you have no output or less than 13.5 to 14.7 volts, let us know that.
Of course.... you are going to have to jump your vehicle, it must be running (turning the alternator for this test).
As for replacing the Brushes ONLY in the alternator, I would have to recommend against that. I know it is popular here for folks to make wholesale statements like: "If your alternator is failing ALL YOU NEED TO DO is replace the brushes". Well basically that is Bull Excrement! Same thing for just throwing contacts in a starter.
Your alternator can be failing (or have failed) for a variety of reasons. IF it a fairly new alternator or has low mileage, brushes are probably NOT the issue.
Your voltage regulator may be shot.
On high mileage alternators....I wouldn't even bother repairing it unless it included a minimum of brushes, regulator and bearings.
Be sure and check the lead from your alternator to your battery while you are at it. Hope you get this sorted out. Let us know what you find.
Flint.
Badly corroded cable will show a voltage drop at the battery which is why I prefer measuring at the alt itself.
True, but only testing at alt may not tell the whole story, so it's good to test at the battery.
If you have to ask how to measure batt voltage you should not be trying to rebuild your alternator.
In regards to testing at alt or batt you can measure from stud to cable, cable to lug, lug to batt post, stud to post and see if you find any voltage drop. Current most be flowing when you test, will show how much voltage drop between two points. Can do the same on the ground side, one lead on the case and the other on the neg post, while running. Anything more than .2 volts is a problem. You can isolate what side and the location.
Isn't it best if the alternator is bad to go and get a replacement with lifetime warranty instead of going to the hassle of rebuild with no warranty?:cool:
