I've had the rig for a month, bought from original owner, but no knowledge of the maintenance history. It's a 1995 with 162k on it. Last weekend I replaced the plugs, wires, cap, and rotor with new OEM bits. Drove it Monday and it drove just as well as it did before the parts replacement. Sat until Wednesday morning and now it won't start. Turns over fine, just won't start and run.
I have power everywhere--lights, accessories, CEL, charge light, everything seems to work. ScanGuage was showing 11.8 V with key on after trying to start and running tests. Had 12.7V jumped to another rig, down to 10.5 when cranking. Tested the fuel pump by jumpering pin 3 in the relay socket to 12V and it runs. Pulled the return hose from the regulator before doing that and had fuel, too. Timing light on plug wire shows spark. EFI fuse appears good, will test it.
I don't know where to go from here. Toyota doesn't currently have FSMs available, so I haven't ordered one yet. Haven't seen the same symptoms in my search here. I always have flashbacks to a broken timing belt and expensive repair to Mom's Acura with these symptoms, so I'm hoping for something simple.
What should I check?
thanks!
thanks!
