Franken-thread alert. Bringing this back from the dead. I'm also striking out programming remotes. Tried both the black and the gray. Need advise as to what's normal. I turn key to on, press green button on the side of the RS3000 box under drivers seat, see "Security" LED illuminate, (within 5 seconds) press the remote button for a few seconds, then release. Red LED turns off and I shut off the key. Nothing. Nada. No chirp or flash.
When I tried to clear the codes the first time, I did get a series of chirps, but all the dash lights flashed also, not just the headlights. Even the radio flashed. Normal? Now back to square one where I get ECU into programming mode, but won't accept codes. And if I repeat the clear-code process, I get zero response.
IH8RS3000
