Rough idle at startup
Hillsborough, NC
Ive noticed a few idle and run issues on my 93 as of late. If i let it sit for more than a few days, it has some weird issues. Sometimes it takes a while to get it started, like it doesnt have fuel in the line almost. Once its ruuning, it idles rough, at a slightly lower RPM than normal. Once it warms up a little it gives no more problems. With that being said, i went wheelin a few weeks ago and was bound up in a spot on a decent slope. After being there for 10-15 minutes, it started running rough. It almost acted like a carbureted vehicle on an incline. It felt short on power as well. Im not sure if all these things are related, but they all seem to be fuel related. Any ideas? I have installed a new fuel pump, filter, injectors, plugs and wires and distributor cap within the last year.
Did this happen before you put in new injectors? Almost sounds like one is leaking fuel into a cylinder while its sitting.
If it were me, I'd start reading through the FSM, starting at the SFI section and start testing components like the TPS, MAF, etc.
Although someone might chime in here with a better response ; )
Thanks for the reply. i swapped a good used engine in last year and these new injectors went in with it.
I also get a raw fuel smell, especially after its been running a while. It almost seems to be coming from around the charcoal canister. I've also read about the "check" valve on the gas tank. Could it be clogged, and in conjunction with the canister, be causing these issues?
Really doubt that the fuel tank vapor recovery system is creating any of these problems, other than perhaps the fuel smell. Got a new gas cap? It does sound like heat may be causing problems in your wiring harness. Is it new with replacement motor? If not, have you wrapped it and tied it away from your EGR pipe?
I had a similar problem last year wheeling in west Texas. Stumbling and surging and lack of power. I am SC'd and was runing 91. It was explained to me by a jeep guy that had seen it many times, the last of winter mix fuel (apparenty we even get it in Texas). He said that winter mix has a lower boiling point ~120F, and I had sat stationary engine and AC on for 20 ish min, while a jeep was being extracted.IE not enough air flow under hood to stay cool. I ended up snapping a birf due to a surge. When I limped back to where we staged, I unplugged the charcoal to tank lines and it started burping raw fuel. it sat and cooled off for a couple of hours and then ran fine.
Maybe a completely different problem, but maybe there is something there?
Yeah, gas cap is new. I did away with the EGR and PAIR valve long ago. I checked the wiring harness when i did the engine swap. I wrapped it and tied it to the firewall just as a precaution. Everything looked good. It runs good most of the time. I hate these little intermittent issues haha
hmm, interesting. It did build up alot of pressure and was actually losing fuel out of the fill neck when i was stuck on that incline for a while. Something isnt right in my fuel system, just not sure what it is.
the charcoal canister is a used replacement. Are there any new replacement options out there anymore?
I just talked to my local AutoZone today who said they can get me the VC120 within the day if I pay in advance but I never made it over there. Maybe tomorrow.
my 93 ran like crap and it was also a bad VAF. i had zero history on the truck when i got it so it was fun to track down with fresh rebuild and 4K into the engine. swapped out the part and now runs like a champ.
The VAF i have is actually a rebuilt unit from a guy i found on ebay. it looked like a brand new one when i got it. I cant comment on the work that was done to it, but when i first installed it, my truck seemed to run better. Are these even available new anymore?
