Rookie biatch
It's a 92 with cloth interior. I doubt I can match the pattern. Not a huge deal though.
thanks man
The CDL lets you manually engage 4 wheel drive (50% front and 50% rear, locked) vs all wheel drive. Selecting 4 low automatically engages the CDL however its handy to be able to do this in high range as well. The CDL is not the same as front and rear differential lockers.
The wiring harness already exists behind the dash, I recommend doing this mod at the same time you upgrade the stereo since the dash has to come apart somewhat for both.
He's got a 92, it should be on the dash already.
Welcome. :flipoff2:
Here's your complimentary avatar.
It kills me this was never implemented from the factory. Was this supposed to be a overpriced option for consumers that the dealer could do for about $5 and 5 minutes of time?
So a night and day difference, huh? Where do you guys see your most benefit from it?
Pages have been written about this. Do a little reading.
The CDL switch was standard on 91/92 and enabled you to selectively lock the center in high range. All full time 4WD 80s lock automatically when shifted into low range. With a small modification, the CDL switch affords you selective control of the center diff in both high and low range. IMO, this is the way it should have always been, but I don't like mechanicals making choices for me.
It is particularly useful when on tight trails to keep all 3 diffs unlocked. It's easier to maneuver the wallowing behemoth through the trees when the steering is not binding and causing understeer.
good stuff, John. Thanks
