Roof Rack options
New Hampshire
I'm new to the forum, I have a 1997 LC and I want to put a roof top cargo carrier on (the metal frame and wire mesh type) , I have the factory roof rack and I'm wondering if it would be better to get a cargo rack that attaches to it or replace it altogether? opinions? and what are the best brands/types?
The OE rails tend to rust (or rather the mountings through the roof) and are not very strong, depending on what you plan to carry get a 6 or 8 leg version, dump the OE offering.
regards
Dave
Thanks, do I just plug the mounting holes from the OEM rack?
Unscrew the existing rack and put some silicone or the bolts back in the nutserts.
A heat gun will help with getting the adhesive strips off - keep the gun moving. Plastic scraper to avoid scratching.
Takes about an hour.
I have seen many different idea's some put matching the paint colour plugs with a dab of silicone to keep them water tight, others recess them and use some bondo, flatten and paint. I have seen them being welded up but that would mean slipping some protection under the head lining. There was one guy who filled them and then painted the entire roof with IIRC something called 'Rhino Liner'? I gather it is the same as we have in Europe, a sort of spray on thick chip/scratch resistant coating?
regards
Dave
Get a gutter mount. But before you do. If you park in a garage. Measure your heights.
My rack that attached to the factory rack. After a bit the factory rack started to pull off the roof from the drag the rack was generating.
Mines a 97 as well. And my factory rack also was starting to crack from the sunlight.
I have a ARB touring rack now. And used Thule gutter rack mounts with long load bars. 3 load bars. 6 gutter clamps. I found the Thule stuff off craigslist for $75. The ARB mount kit was $375
And everything works great now.
Before adding the load bar end cap. I cut that one down a bit after cutting the top rack bar. From the tent to the LED light. RTT was hanging off the end of the rack by a foot.
This is the old factory rack mount rack. It worked great till it tried to remove itself. And well my RTT wouldn't fit with it anyways.
The new rack and awning. Before the RTT was installed.
The new set up now.
That is sweet! What RTT are you rockin?
The new set up now.
Any planning permission issues? :eek:
Looks great, makes my Sahara RTT look rather wanting.
regards
Dave
It retains the water. You might as well salt the panel. lol
That's new!
I know there are different types of silicone but never heard of one that retains water? Are you or the previous poster saying the silicone absorbs water or simply allows it to get trapped?
Used it for many years on 'Crittle' windows in the UK's beautiful damp climate, never saw any rusting.
regards
Dave
Sounds like they're speaking of moisture still being inside the roof cavity and the silicon sealing it inside. Mine hasn't leaked yet, and I hope it doesn't, but when a RTT is within sight price wise, then a guttermount rack will go up and I'll do the same to the holes. Living in California, the summers are hot, so I'll leave the holes open for a day or two in the heat, and silicon it in the late afternoon/early evening, hoping it's dry inside. But, if you here's already rust, then its only time. Rust really is car cancer.
@Phildoh, I agree, it is interesting that I drilled and fitted a 'shark fin' antenna, plenty of silicone and bolted it down, need to look through the thread in my sig but it is definitely over three years ago and I live by the sea...and I mean...within a couple of hundred yards.
As the shark fin is coming out as it sucks I will look for rust, if there is or is not I will revisit this post and give all the gen.
regards
Dave
