Roof rack lights, how'd you run your wires?
Quito, Ecuador
I'm going to wire up my roof rack this weekend and was curious how others have done it. 40" led bar up front, 4 side lights, and rear backup lights.
I have a bluesea breaker that runs to a bluesea fuse box. I ran two pairs of 14ga wire inside a 3/8" plastic wire loom out the engine bay and up the C channel in the windshield on the passenger side. All my connectors are DT, which are supposedly weatherproof, but I used heat shrink and 3M Super-88 tape to be sure. I just put some black RTV in the C channel and the 3/8" wire loom fit in there snugly. On the roof I used UV-stable high strength zip ties, since the cheapo ones will degrade and break over time in the sun.
Make sure any wire you use is automotive grade. SXL/GXL/etc. I have a post around here somewhere with a few photos of the install, but if you need more advice I can take photos and post my materials.
I'm interested in the penetration from the engine bay to the a pillar. If you could provide me a link to your previous post I'd greatly appreciate it. Or if you could take close up shots of the penetration and the "ride" up the A pillar, that would be helpful too.
Only thing I can't find is the battery cable I used. I think this is everything else:
Air On Board switches I used for front LED light bar and rear camp lights:
Push switch 907G 12volt Toyota OEM Replacement LED LIGHT BAR green SW907G 1
Wire Plug 1 x Wire Plug $0.00 SW800WP
Switch Body 1 x LED GREEN $0.00 SW9W00GBN
Switch Cover 1 x LED LIGHT BAR $0.00 SW907CVN
Push switch 9B04G 12volt Toyota OEM Replacement REAR LIGHTS green SW9B04G 1
Switch Cover 1 x REAR LIGHTS $0.00 SW9B04CVN
14ga wire I ran up to the roof. I bought this from wirebarn.com:
Item # Description Qty
14-GXL-RED-100F RED 14 Gage GXL Wire 1
14-GXL-BLACK-100F BLACK 14 Gage GXL Wire 1
STDFUSE-5A-5 Standard ATO ATC STYLE 5 AMP Automotive Fuse (Tan Color) - 5 Pack 1
Blue Sea Fuse Block 12 circuit with negative from Amazon
Amazon.com : Blue Sea Systems ST Blade Fuse Block - 12 Circuits with Negative Bus & Cover : Fuse Block With Relay : Sports & Outdoors
Hammond ABS box from Amazon (which I mounted the fuse block inside to help protect from water):
Hammond 1591ESBK ABS Project Box, Black - Electrical Boxes - Amazon.com
3/8" wire loom (though you don't need anywhere near 100')
Amazon.com: Absolute USA SLT38 3/8-Inch x 100-Feet Split Loom Tube: Car Electronics
DT connectors and the crimp ends from mouser.com:
Line
No. Mouser Part Number
Customer Part Number
Manufacturer Part Number
Description Quantity Ordered Quantity Shipped
1
654-AT06-2S-BLK
MFG Part No:AT06-2S-BLK
AT06-2S-BLK
Amphenol Automotive Connectors
US HTS:8536694051 ECCN:EAR99 COO:CN 8 8
2
654-AT04-2P-BLK
MFG Part No:AT04-2P-BLK
AT04-2P-BLK
US HTS:8536694051 ECCN:EAR99 COO:CN 10 10
3
654-AW2P
MFG Part No:AW2P
AW2P
US HTS:8535908040 ECCN:EAR99 COO:CN 10 10
4
654-AW2S
MFG Part No:AW2S
AW2S
US HTS:8535908040 ECCN:EAR99 COO:CN 8 8
5
654-AT60-14-0122
MFG Part No:AT60-14-0122
AT60-14-0122
US HTS:8535908040 ECCN:EAR99 COO:CN 20 20
6
654-AT62-14-0122
MFG Part No:AT62-14-0122
AT62-14-0122
US HTS:8535908040 ECCN:EAR99 COO:US 16 16
1RoHS: Compliant
I'll take a photo, but I basically just notched the black plastic at the bottom with an exacto knife to fit the loom and then used some RTV to seal the gap (though I think that's unnecessary really). I probably could have skipped cutting it but the hood would have crushed the plastic loom.
This thread has a lot of the details though not the actual pic I know I have but am looking for:
What have you done to your 200 Series this week?
A little blurry but here's a photo which shows the spot I notched.
