Roof Rack Lighting ?
Nashville, TN
I have searched and found some info, my question is how have those of you who have roof racks with lighting routed you power connections, both from the cab to the rack, and around the rack ( internal, or zip tied)
thanks, and pics would be great, im close to finishing my rack and want to plan the final details before i finish it
I am having to think about this myself.
https://forum.ih8mud.com/80-series-tech/194814-auxiliary-lights-wiring-questions.html
I went with a separate 6 point Buss Fuse block to handle all the extra power I will need to run the light relays and such...and mounted it inside the engine bay....I also mounted a 8 position terminal Block (Home Depot) in the engine bay to handle the grounds....The terminal strip is grounded to an engine ground location as pictured. I found this to be a convenient way to centralize all the electrical grounds for accessories..(only bad thing is having too many wires going thru the firewall hole....)
As Far a getting switched power to the light switches....read the post on top...Many options....I am going with a 98Snake Eater solution and use the Ad-A-fuse from the main fuse block where it will only provide power with the key in the ignition.... My project is half way...though...still waiting for my pair of flood lights to come in.
Can't believe I am providing advice on here now... LOL....but this forum truly is a great resource and learning source....
When I bought my KC HiLites, they came with the wiring harness. It doesn't reach very far, but makes it very easy to hook up, plenty of instructions and I called them and got an answer when I was doing my roof rack. I have 4 lights. 1 relay for the outside lights. Then one more relay for the inside 2 lights. One switch that I got from RadioShack.
The wires are routed along the passenger side up the seatbelt cover and out the door. I zip tied them together so they could fit in the jamb. Doesn't look the best, but no drilling. Make sure your lights are don't interfere with the windshield. All those little dust particles will be lit up and you won't see a thing. So make sure if they're hanging over or are pretty close to your wind shield, you make a visor for them, or move the lights mount back. Good luck, can't wait to see it!
I made mine too!
thanks guys, im not as concerned on the power connections as i am on the routing, ive seen snake eaters, i know i have seen others with lights on their racks and it gets there somehow
rack lights
Hi I have a rack with two lights, I routed the power wires trough the roof behind the lights.
More pics here https://forum.ih8mud.com/80-series-tech/188820-my-roof-rack-ready-new-pics.html
