Should these face forward or rear?
The tabs are forward under the anchor point about which is also forward. In a stock setup the screws for the corner pads would reference it since those have small screw holes and on the back to protect the rear passengers.
Are you saying that those big ass brackets are factory?
Can’t help with your question but interested to know what the rebar is for.
While I don't think the welds are stock believe the brackets are. I have a couple loose roll bars. One is a 77 the other one believe I pulled out of a 80. 80 has the tabs and will snap a picture or two tomorrow.
I think I also have here the brackets Toyota welded to the hard top for three point seat belts here until moving it to the roll bar and other markets that didn't a roll bar.
@Living in the Past the past ,
how are you Sir !
- what usa-spec model year were factory toyota roll bars introduced as a standard option ?
- What year did Factory Lap Belts w/ the seat lower mounted retracter , phase
out and 3point shoulder harness show up ?
- i think this is a Very Early , Lap style only Retracter Belts equiped Factory TOYOTA Plant A11 installed standard Option / standard equipment Rolll bar ?
maybe .................![]()
thus the need for a PO to add the shoulder belts 3 point Brackets like we see here ? when a later model seat belt was added or updated etc ............
The '77 hardtop sides that will be going onto my '71 FJ40 build have the provisions for the 3-point harness retractors, and the '77 roll bar I'll be using doesn't have the tabs. IIRC the tabs were added to the roll bar in '78. My '76 FJ40 doesn't have 3-point harness seat belts, so I think '77 was a unique year.
Looks like the roll bar change came about in 02/78, followed by another change in 01/79.
Yes I show the 2/78 as the change for the roll bar. Guess my 77 could be a early 78. I know it's not earlier because of the sharp radius on the back pieces to clear the latch for the pop out vent windows.
My 79 currently has a 77 top sitting on it.View attachment 2180072
It has the spot welded pieces for the seat belts. I remember when I bought this top and don't believe the roll bar came from the same vehicle but if could have.
I bought this top and another one from a 1/75-12/75 cruiser at the same time. 1/76 three point seat belts were required in the US. This change didn't happen at the start of the model year like most changes. My 10/75 76 model does not have three point seat belts. The wrecked 84 HJ47RV I stripped parts off had the seat belt brackets spot welded to the sides. I picked this up as a possible way to use three point seat belts in my FJ45. I have the top anchor brackets used on Canadian FJ45s. Which like the vents in the hard top sides were Canadian market only.
Just to show how crazy prices have gotten I bought the two tops including ambulance doors for $200 apiece. This was probably a little over twenty years ago.
how did you get the 97-98 SR5 T-100 Alloys Rims to fit a solid front axle ?
the tie rod end interference issue ?
Upon graduation of T-Ten in 1998 , I bought
one of the last ever imported T-100, s new off the lot ,
it was the last partial production. Year and
was POSH with JDM perks :
- Power moon roof
- special fully adjustable captian chairs front seats
- I financed the newly introduced TRD 3.4
Super charger on it and a TRD stainless exhaust
- best of all it was a all cloth interior
not some primida Leather .....
I miss that truck .......
That is a 1979 + rollbar. You have it reverse, those tabs should be pointed towards the front your 40, towards the gas filler. The seatbelts mount to to that.Should these face forward or rear?
