Roll Bar Question
Golden, CO
So I have a "custom" 6pt roll bar that came in my cruiser. With the new seats I have installed my head is sitting closer to the bar that runs perpendicular between the A and B pillars. Is there any safety issue with cutting it out and moving the bars 5-6 inches to the midline?
This mod would get the bars out from over my head and then could be used to house and overhead console for speakers and a dome light.
What are your thoughts? Thanks in advance.
Dan
Here is a pic of the rollbar for reference.
I think I would move them out if you can and add two additional in the middle if you want them. Just my opinion.
I agree with Brad, I would move them out to the middle of the bends on the A and B pillars.
I 3rd the motion, But I would also add 2 in the middle, I figure the reason for doing it is so a big rock wont squeeze in between the outer bar's, Put some padding on the outer ones so you dont crack your head on them every time you get in & out.
Good luck
:idea:
Lower the seats. :flipoff2:
Agreed. Two center spreaders and two outboarders.
The seats are as low as they will go. Thanks for the input. :D
I figured I'd need to move them out but you all confirmed it. Thanks!
drohweder said:
The seats are taller than stock seats as they came out of a 1999 toyota solara. Mind you I still have 5 inches of clearence above my head but theoretically I could crack my head on the roll bar if I roll.
Nothing theoretical about it....First post rollie purchase was a set of Simpson harnesses.
OUCH!!!
I was thinking about the 4pt harness but have since settled on the shoulder restraint. I just better be careful not to role or bring a helmet with me. Gonna pad the bars wherever they end up.
Dan
My problem with 5 point sis when I need them, I am never wearing them, I am usually in a lap belt with my stupid head hanging out so I can see where I am placing my tires.
I padded my cage and After this Moab trip I am Adding new seats and Harness's.
Jetboy said:
I think that you would be better off structuraly making a cross above. It may also give you the clearance around your head.
Not meant to rag on Jetboy, but a cross, while it may strengthen the cage, will definitely INCREASE your chances of metal contact. What you need is a metal halo!
P.S. If I roll, I figure it's anyones guess what happens. No outside spreaders. :o
If your head is high enough to hit the cage I don't think the cage is likely so save your head in a roll over. what ever you are rolling onto will penitrate the cage somewhat unless you are on a resonably flat surface. The furthur laterally the bars are from the head the higher the likely hood of something penitrating the cage and hitting you. If your wheeling in rocks this is a concern.
My cage is a 6 point with two parallel spreaders in the middle, but I think that two spreaders coming in from the outside front to the center of the rear hoop and possibly two outside spreaders would make a stronger and better protecting setup.
I also don't think that the factory mounting of the cage to the sheet metal is strong enough.
I do think that the ultimate solution is to get lower seats or a taller cage.
