Rocker drains
carlsbad
From the posts that I have read I think these are the rocker drains. They did not seam plugged or of an adequate size. I had a ton of water in there. Is it ok to keep the front plugs out?
From your pics, I'm not sure you're in the right place, but close. The drains are a series of (4 to 6?) D-shaped holes that are stamped into the downward facing seam of the rocker panel. There are some bigger round holes with rubber plugs, but these should have rubber plugs in them unless previously removed already. The plugs can be left out if you're in as place where salt is spread it might be wise to keep them in place once you've opened up the smaller D-shaped holes with a ziptie as you show in your pic above.
Forcing a metal tool into the slit drains to open or widen them can break the paint protection and lead to rust, so might be a good idea to go back and brush something up into the slits to protect them a bit. Many people find that a plastic zip tie works well to remove any crud in the drains. FWIW.
2nd pic is a drain; cannot determine in first pic.
The doors also have weep drains.
Yes, I forget, 4 each side?? bottom inner aspect of the rockers, a bit
hard to find as they aren't very wide open, just a flat slit, wide enough for water to drain out as long as they aren't clogged with mud. Get on your back
stick your head under the vehicle and look at the backside of the rockers
near the bottom, look for a small squarish bulge.
Here's some good images from 2007 thread:
I've opened them up in the past with a flat blade, round shaft screw driver. Just tap the screwdriver into the hole until the round shaft has penetrated past the pinch weld.
IMHO a 1/4" round hole is less likely to clog than a flat hole
Should be accessible with a small flat screw driver (if they are damaged), otherwise a small diameter cable, like a garage door cable, fit in the slot and may need to be moved around if you have caked mud in there.
Amen! Don’t force metal in there. Re: the plugs, I leave the back ones out - but I’m in the south w/o any road salt.
