You and Jordan and the bloody flouro paint. Sheesh.
Haha! Thats hilarous; you totally had me...
Well here they are after a long but awesome afternoon/evening. Abel was awesome to work with and a huge help.
Looks good man, amazing what he can get done in that cramped little shop of his eh?![]()
...before I get too deep into the legs, wondering what type of mount you guys would recommend. Current options:
-Welded to frame with gussets
-Bolt on frame
-Slip on (from bottom) with bolt on top of frame
-U-bolt mount
Bolt on is simple in the respect that I can do the mounting at home, but findings angles is trickier
Weld on is simple if I have access to a welding machine or if someone is able to do some welding for me, also the quickest on the fab end of things.
Thoughts?
G'day Franken60, those sliders look really good. I assume you ended up welding them on? Do you have any pics of the chassis mount / pads where the welded connections are? I am interested to know approximately the size and thickness of the pads.
I'm doing a set for my 105 and also wondering whether to weld or bolt. I've seen many variations of bolt on + brackets etc but very few pics of welded rock rails onto the chassis. I work for a welding and fabrication company so no problems getting it done, but speaking with one of our engineers, he mentioned (in his opinion) that welding a pad onto one side of the chassis would not achieve the same strength as with a full wrap-around bracket like this one below.
My 105 is a family tourer and not a competitiion rock crawling beast so I don't need ultimate strength, and I find the welded option more appealing as it is "fixed" onto the chassis - one less thing to worry about coming loose when travelling 1000's of corrugated kilometers in outback Oz.
Hey Hendrik, I pm'd you some details
Thanks mate, appreciate the info! After speaking with a few more people in the offroad fabrication business, I have decided to go bolt on with similar mounting to pic above in my previous post. Once done will post some pics.
I don't think you can weld them on in Aus without an engineering plate added?
