Rob's FJ45 Build
do you need a newer firewall chunk and pedals? i just cut 2 out last weekend for such a project..
Would a trans tunnel or 80 series fire wall help you can have it if you cut them out. Have a carcass going to the scrap yard with in the week.
That might be a better option. Try the 80 pedal and firewall. No need for a clutch pedal
Not sure if I could use either as I plan on making a new flat firewall, using the 4.3 v8 I don't need the hump in the middle and do need the space on the inside for the hvac.
Have modern Hvac 80 and 100. Getting ready to scrap the 80 and not pulling the Hvac stuff it you pull it’s yours.
More progress over the past couple of days
Got all the welding on the bottom finished up
Welded up all the holes on the dash
So many variables to choose from there. U got this!
Modified the brake pedal bracket to accept a newer brake booster and got the back side of the dash primed before installing the firewall.
Started building the frame first step was to remove all the spring hangers and shock mounts, then it was on to removing all the inner support structure.
Got the cab mounts all lined up and finished welding in the new firewall and braces.
Outboarding the rear spring hangers so they line up with a 60 axle, this will also make room for my spare tire to fit in the back underneath the bed.
transmission crossmember andn skid plates
motor sitting nicely in the frame
closed in the floor pan around the transmission to get a little more foot room.
Just wanted to pop in and say Your doing great and it is looking awesome.
The "One Pedal To Rule Them All" concept has me intrigued.
The engine I'm using is drive by wire so I just need a bolt the pedal to the firewall
Progress moving along
seats from a 2002 Subaru Forester nice they come with heat built-in, will probably end up dying them a darker color
old air heat and AC unit tucked neatly up underneath the dash,
60 series brake booster and 80 series master cylinder
the villagers demand an update.
