Riveshat balancing
Which way was it when you pulled it out? Some of us with lifted rigs have changed phase back and forth to find the smoothest results. If you don't like it just pull off the lower end and reindex by 90 degrees.
I was wondering about this too after having my drive shafts balanced about a week ago and all new u-joints. I called the shop that did the work asking about it and they said they are aware that the FZJ80s front shaft is out of phase from the factory but they purposely balance everything in phase. Didn't make sense to me but figured they know more about these things than myself. My only remaining question would be, if I were to reinstall the front slip yoke out of phase by rotating it 90 degrees, would the front shaft still be balanced? Wouldn't changing the yoke orientation alter the balance of the shaft assembly?
Yes it will, if it was balanced one way, rotating it will make it out of balance, since it was balanced that way
That's what I thought. Thanks for confirming.
