Right model 79-85 mini ps gearbox?
Santa Monica, CA
Website
www.elirubelphotography.com
Ok so im going to the junk yards and I say....Im looking for a PS gearbox from a 79-85 toyota truck...doesnt matter which model...then they say 4wd or 2wd?
My question is which one to get one outta a 4wd or 2wd
I assumed 4wd...but wanted to make sure
The guy I talked to said there is a difference between the two boxes
Also... If I can get it locally is $125 a good price?
Thanks
Eli
You want one from an IFS truck. the 79-8 somethings used push pulls..
2wd or 4wd will work IIrC..just make sure the donor is an IFS rig.
Unless you are putting crossover steering on a SFA minitruck this is completely wrong. You want a 79 - 85 solid front axle 4wd minitruck box to add "minitruck" powersteering to a 40.
John is correct, 85 or less 4x4 mini truck box, and 125 is probably ok, I looked quite a while and did find one for 100, but like I said I looked alot.
Agree to the $125 if they throw in the high pressure line! You will need that too if it is in good shape.
Good luck
