- Thread starter
- #21
clearance is good. license plate at like 80 degrees open is about .5” and same to 90 degrees.
Quick question: do your wheels have zero offset?
they are. 16x8 et0 they do rub the cab pinch weld, I havent gotten around to cutting and flattening it out, cutting its only a minor annoyance.Quick question: do your wheels have zero offset?
How long of an extension do I need for my Thule XT Pro T2? 4 inches should clear a 12.5” wide tire.
Hi,So, the mega is an option as it's arm is actually a tad lower, but the upper is taller. The regular ultraswing with the high offset mount might be a great alternative and technically the arm is a slight bit higher.
Heres mine. 16x8 et0 285/75r16
View attachment 2442525View attachment 2442526View attachment 2442527
i’m not sure i’d message those guys on ig.Hi,
Nice rig! Is this the ultraswing multifit? Im picking up one today and wanted to know if a 35's fit on the spare mount with same wheels. No rubbing? No extra part i need to buy? The ultraswing multifit that im picking up came from a tacoma. Thank you in advance.
Old thread I know, but what about stock Tundra 18" wheels? any idea if those also need a spacer?Yes, I would go with the Mega if this is the route you take. Remember, the spare tire bracket is too short and you will need spacers if you run stock 100/200 wheels. Good luck!
Don't have an ultraswing but would love one!Ok, bringing back this topic to anyone who has installed an 18" Land Cruiser or Tundra wheel on an Ultraswing spare tire mount.
cc'ing @ElHefe @blackohio @shtbrwn86
What wheel adapters or spacers did you use and how have they held up?
