Hello all, My truck is an 88 4runner 22RE 5spd named Jubei
I also have a 85 4runner and a 79Fj40. I wont be able to do this all at once but I will get started and then elaborate as I get time. here are most of the specs I have done all the work on this truck myself and I have built most of my own accessories. I even repaired the rust and body before repainting it recently. This is my DD and it sees a lot of miles on and off the trail. It has about 285k on it now and I add another 1.5k a month. I take this truck out on the trails of utah about once a month maybe more and it hauls all my gear with little complaint. I have had this truck for a little over 5 years and it was stock when I got it. I love to rally this truck on all sorts of trails as it is good all around not real aggressive but still smooth on the freeway
Engine:Rebuilt 22RE
K+N FIPK custom intake to a later model plentum
plentum, head, and intake ported and polished
4mm oversize throttle body from LCE
Balanced injectors
oversize stainless steel valves
LCE EFI pro cam
LCE Dual roller T-chain conversion
LCE Stainless header + free flow cat
bottom end borred .5mm oversize
new Toyota TPS, alternator, starter, motor mounts, belts, and hoses
Drivetrain and accesories:
4.88 yukon gears w/ e-locker rear
4.88 IFS front
Double cardan drive shafts F+R
14 gal. Long range fuel tank
front IPF 100W lights
3 pairs of rock lights
custom header oven (for warm meals on the trail)
spare parts tray under the aux gas tank where the spare tire was
Yakima roof rack
Limb risers
33/10.5/15 BFG all terrains on Tacoma wheels
Suspension:
Front: IFS Toyota torsion bars
1.5" ball joint spacers
modified upper and lower control arms w/reinforced shock mounts
low profile bump stops
Poly bushings
Sway bar disconnects
Modified idler arm with bracket
Frame truss
New Toyota ball joints and tie rods
Rear: Downey springs with a TRD Tacoma main leaf added
1.5" lift shackles
U bolt flip with custom shock mounts
Armor:
Custom rear bumper tire swing with 5gal. water can holder, aux. light, receiver, and retractable mud flap cables.
Custom front bumper with light mounts, recovery receiver, light guards, and limb riser hooks.
custom sliders and low profile cross member skid plate
reinforced skid plate
Rear diff armor and elocker guard
Interior:
Custom diamond plate interior with locking storage boxes full of spare parts and gear
SR5 gauges and seats w/custom covers
Alpine ipod ready reciever 2-6x9s, 1-10sub@250watts, 2-61/4s 2-tweeters
cobra cb
sure fire rechargeable flash light
shovel w/quick fist mounts
3 aux power ports and GPS w/dash mount
Engine:Rebuilt 22RE
Balanced injectors
LCE EFI pro cam
4.88 IFS front
Yakima roof rack
Limb risers
Suspension:
Poly bushings
Frame truss
1.5" lift shackles
Armor:
Interior:
cobra cb
