I am starting the rewiring of my cruiser and instead of getting a kit like EZwiring sells I am doing it from scratch. I figure there is alot that is needed there kit does not supply anyway. The cruiser had nothing in it when I got it.
First thing first is the ignition. I have a kill switch to an ignition switch and seperate push button starter. Ford 3 wire 100A alternator is in.
I have 4 gauge grounds from head to battery, block to frame, and battery to frame.
4 gauge hot to starter. from the starter to kill switch with 10ga, kill switch to ignition with 10ga. and right now to pushbutton with 10ga. and then right back to the starter sart post. I just picked up a 6 circuit fuse block and have a 75 amp bosch relay I would like to use to power the fuse block with ignition switch.
fuse #1 I would like to go to the push button starter, excite wire to the alternator, and power to coil. What size fuse do I use for this circuit?
I have 4 gauge wire going from the alternator directly to the battery.
I have heard of fusing this wire. Should I go with a 100amp inline flat blade style
mega fuse that I have seen. Is it really needed?
Also I hear I should run a fusible link from battery to starter. Well that is 4 gauge wire. a little 14 gauge fusible link seems stupid, so should that also be a large amp mega fuse??? What does the starter draw, Confused on what size for this stuff. Haynes and stuff really dosent say. Would like this to be a beefy system that will last a long time. and also as simple as possible.
What kind of info can you throuw in from what I have said of the plan and where I am heading with this. It is a 66' so no hazards, no backup, no cig lighter, no radio. Just the VERY basics. wipers, lights, ignition, heat, best way to fuse the ignition stuff, should it all go on one, seperate? Info please.
Thanks for the ramblings, Mike.
Any info appreciated, I am definetly a wiring newbie, and dont like fires.
