Reviving a 2f from the woods
Don't have a problem with the idle. Idles smooth and 19 on the vac gauge is good number. As stated, the start up rpms are still way too high with choke pulled. It warms up quickly and after a minute or so will idle excellent with no choke. My problem is just working out the balance of the 2 idle stop screws. I do have vacuum line to the diaphram closest to the firewall. I sprayed starting fluid all around manifolds, carb base etc a couple days ago. Not even a hint of a leak, fuel cut solenoid is new with 0-ring. Today I will change oil and filter, run it some more and move on to next project. I just may mount the tranny and xfer case, and it will all sit here in my side shop until I come up with a sutable donor. I wonder if that fj 45 frame has a title? :)...... Oh yeah I know starting fluid is not safe, but it was just sitting there and I was really careful.
Did my oil change, did some engine cleaning (shouldn't have started that) and planned to do the valve adjustment right after the Mariners game. Sheesh, we're heading into the 15th inning scoreless. Now the engine will be totally cold.....Go M's!!!
Figured out my idle situation. A person should never have two brands of old vehicle passions going at once. On the flathead ford V8s the idle stop screw is adjusted from the passenger side so that's what I was doing. I just had the two stop screws reversed in their purpose. Adjusted the valves, cleaned up some wiring etc, cleaned shop, put the 2F under a cozy blanket and called it a night. I consider this back woods 'revival' to be a complete success and a worthy endeavor. Thanks for watching and helping. Gary
Gary ,
i am extremely intrigued by what you have going on here in a wide eye'd skool-boy in VO-TECH at age 14-16 age : :D
i would like to donate anything u see below to your cause , please simply allow me to help another Kindred Karma Spirit such as your self get to what ever place your going to .........
- what matters is we as a community help one another in any way we can when ever wee can .........😇
- these fittings will replace the orange hose one ,
i do NOT think you need the choke breaker hooked up , rather MANIFOLD ABSOLUTE Vacuum to the Dizzy diaphragm is my thoughts here .......🤔
PM me your shipping addy
It’s all In mondays mail
Gosh, thanks Matt. I have some parts we can talk about too. I will send a PM
