Reverse Lights - SOLVED
Cedar Rapids, IA
So I'm trying to hook up some LEDs I had laying around for added reverse lights. They have a red and a black wire. When I test them directly to my battery they light up like Christmas. When I try to tie them in to my reverse light harness they don't work. I know this is simple but I can't figure it out. The reverse light wires are white/black and red/blue. The red/blue lights up my test probe when switched on. So I assumed that goes to the red wire of the lights. Nothing. So I tried the black. Still nothing. Am I missing something obvious?
LED are sensitive to current, so switch the wires. I think that 80's are grounding type lights, meaning the ground is switched.
What he said.
I should add that I have added LED bulbs before with no issues.
Ok. I'll try again. My front LED spot lights worked without a problem. I knew the 80 were grounded switched from that. But for these I just ran wire without a relay or switch. Just wanted them to be blinding when I threw it in reverse so I could see backing up.
Thanks for your help.
I think all it'll take is switching your + & -. Should fire right up! Also, my reverse lights turn themselves off after about 3 minutes so if you plan on using these as camp lights as well you'll have to put them on a switch or keep putting it in drive then reverse each time they turn off.
I ran all the wires through the tailgate and in to the DS quarter panel where I'll make the connections. Just didn't feel like messing with it anymore tonight. I'll finish it on Friday (no school because it's the end of the trimester). It's only for backing up. When I get my yodateq mounts I'll order new LED floods for them to match my spots in front. I'm going to build a roof rack this spring that will have camp lights mounted on it. This was just a "hey, I've got these DRL strips that came two to a pack. I'm putting one under the hood for a under hood light. What should I do with the other one? Oh, reverse light!" Because I have nothing else to do to my 80... haha
Ok. Going to dig back in to this. Never got the lights to work. I tried flip flopping the wires and get nothing. Touch them directly to the battery and the light works. Thoughts?
try your old lights again...just to make sure nothing got pulled out or twisted during led install or wire run.
Existing reverse lights work fine. I just crimped a lead off of the two wires going to the reverse light socket and put spade connectors on them so I could plug the led light strip in to it. I get nothing. My test light lights up when I check leads off the reverse lights. I'm baffled.
Voltage is voltage. This does not make sense. Here is what I would do to check this out.
Put a meter on the plugs and see what your voltage is. LED's typically work in a voltage range. If there is a short somewhere, it may be draining it.
Check for ground. I would put a alligator clip on the positive lead at the rear light onto the led, then put a wire from the negative side of the LED directly to the frame.
Ok. Figured it out. This is going to sound stupid. I was turning the ignition switch to the accessory position and using the shift lock override to shift to reverse. The normal reverse lights were working but not the LED lights. I unwrapped all of the wires going to the tail lights thinking I screwed up. Nothing. So I had my son turn the car on and actually put it in reverse with his foot on the brake. LED lights work.
So, yes, they are incredibly sensitive. Now to solder everything and wrap everything back together.
Thanks for all of your help.
Thanks everyone for your help and for helping me think this through aloud.
And @NLXTACY I changed the title! (I honestly didn't know you could do this. Maybe because I've never solved anything before...) :flipoff2:
Woohoo! That doesn't happen too often here :flipoff2:
