Returning oil leaks
Triplett nc
ive had my land cruiser for about 9 months. And within 3 months of having it, it had a major oil leak. The oil pan was bad, so the mechanic replaced it. Then 2 weeks later another leak came up, and I brought it back to the mechanic. He took apart the whole engine. Found it and replaced the seal for over 1000 dollars. He told me that I was chasing butterflies and I shouldn't repair oil leaks. It was an old car and that it was going to leak oil. Then a week later a new leak showed up. And now the rear main seal leaks too. So I brought to a different mechanic who told me it was 3000 to fix. So I decided against it. But I drive the car only 200-300 miles a month and it's mostly highway. And I put oil in it about once a month. I will be driving it a lot more in the future. Is it worth it to fix the leak?
You need to check and make sure this things not building up gobs of crankcase pressure.
The mechanic said it was because the seals were weak and brittle. But I will look into that. How do you check it?
"He took apart the whole engine"
Where exactly on the engine were/are the leaks (be specific) and what exactly was done for the $1000?
Most common oil leaks are:
Oil pump cover located lower front of the engine (often mistaken for a front crank seal leak)
Rear arch area of the long aluminum oil pan (often mistaken for a rear crank seal leak)
Distributor O-ring
Valve cover gasket
Crank position sensor (front bottom oil pan)
I'm not sure. He wasn't specific. It took him 2 days to find the leak. I know it wasn't the distributor o ring.
Assuming oil is 5 dollars a quart, then 600 quarts.
I'm running into a similar issue. I got 1 oil leak repaired at shop A, started leaking again, went to shop B to fix it. Same leak and an additional one on the rear main seal. Hella expensive to fix at the moment, because the transmission has to come out. My current plan is Make sure to check oil more frequently and wait until I have another major repair in the engine bay so I'm not paying twice for the removal.
From what I understand oil leaks can be dangerous if the oil is leaking on the exhaust system because of the high temperatures. Otherwise just make sure to keep it topped off so your engine doesn't seize.
For those folks that know nothing about automotive repair:
Fortunately I do all my own work. I have built up quite the inventory of tools and equipment over the years and I have LOTS of experience. Yes, I've made a few mistakes, but I typically only make a mistake ONCE.
I'm sorry you all must endure the IDIOTS out there that have actually had TRAINING to do their jobs....poorly.
If you are going to own a Land Cruiser and want to be part of it, even if you do NOT do your own work, get hooked up with your local club. Pay the dues, go to the meetings, and make connections with local club members. Be willing to buy beer, barbecue, pay for sports tickets, WHATEVER, but please get advice from those of us that actually work on these BEFORE you take it to yet another incompetent shop.
You can walk into a shop recommended by the locals with a list of what to repair or replace in the ORDER it should be done.
READING a lot on this website will guide you and direct you what to look into. Spend the time. It's worth it and you just may learn something. Yes, there is BS within these walls, but most of the BS is filtered out if you read far enough. Read each related thread IN ITS ENTIRETY so you can see problem, resolution, solution and maybe even get feedback on what they would have done differently ("lessons learned")
Yes, oil leaks can be dangerous, but ONLY if they are catastrophic leaks that SPRAY hot oil onto a VERY hot exhaust so that the smoke makes it so bad you cannot see and crash into something. Your typical leak, (making a puddle on the ground) would not be considered "dangerous" until you slip and fall and break a hip due to said leak. Car repair shops are like the News Stations. They tend to over exaggerate most things and you can't tell reality from the BS.
There are many baselining threads as well as oil leak repair threads that cover just what you need to look for. Go to the FAQ section to find the pertinent threads or maybe even try.....dare I say it.......the SEARCH function......... Of course, that means you must know WHAT you are actually searching for.
Good Luck! Search well. PM those of us that appear to know what we're talking about. We'll try NOT to be a smartass. I said try.......
^X2
@BILT4ME beat me to it pretty much.
Taking a 20ish year old vehicle that you know very little about to an unknown mechanic, is a recipe for broke with a side of future 80 series for sale listed in the classifieds.
Read up here, lots. Then read some more and ask questions. I'm more than new to the 80 series, but can fumble my way around with a wrench. Coupled with the knowledge here, there's nothing I've paid anybody to do on my 80 except for welding some exhaust work, I suck at welding.
Not to beat some of you guys up, but there's numerous options out there to drive that require less maintenance and money. If you're just looking for the "cool" factor and your toolbox consists of a couple of standard wrenches and a hammer, you're driving the wrong vehicle. Unless you have a knowledgeable mechanic nearby that you can trust and afford when the time comes.
At least in my case, I was led to shop A by another MUD member, and did not do my due diligence. I have since found ACC in Atlanta and trust them to do anything I can't fix myself.
Good deal! Again, wasn't out to insult or bash you by any means, being the whole interwebs thing it can be rough to communicate at times.
This is the gateway drug to endless shop visits and thousands of dollars spent chasing "butterflies." I'm not advocating you learn about every seal on a 20-something year old engine, but keep track of when and what is replaced. This keeps one shop from changing "everything" resulting in a leak and you taking it to another shop to again go through "everything" and in another year you'll replace that "everything" again. This is to prevent yourself from getting hosed over and over again by every shop in town.
20 year old engines leak oil, yes. They also have a finite amount of seals. It's completely possible to keep on top of it.
