OK, what am I doing wrong? 2008, I had noticed the Spare (top in the list, it doesn't say which tire is which in the display) was getting kinda low. On a road trip for Tgiving - TPMS warning light comes on, and the annoying yellow warning triangle center dash. OK, fine, stop and check air - all look fine but went ahead and added some to all four drive tires (not spare) to about 37 hot. Figured I would get the spare later.
Later came, aired up the spare to ~33 cold. Attempted the procedure above, multiple times. No love. In fact, my light blinks for 60 seconds and stays on, indicating I need to go to the dealer. Really? I know the tires are good.
When I attempt the procedure - I can hold the (really freakin' hard to find the 1st time) TPMS reset button down indefinitely - no change in the blinking light - it blinks 60 seconds and goes solid. I.e. I can't tell that the button is working, assume it is not - since I can't verify 'blinks 3 times'.
It was "working" fine before the spare got low - and it WAS low - low 20's. I guess it could be coincidence it just so happened to get a TPMS system fault at the same - exact - time - but, come on.
I can't tell for sure, but if the TPMS sensors in your wheels are the originals from 2008, then a good guess is that you have one or more low batteries in a sensor(s). Low battery condition would be exacerbated by low temps in the winter. Dealer, or any good tire shop, should be able to check battery status of your sensors with a common TPMS tool. Since the battery is not a replaceable part, if a low battery is found, it means a new sensor must be installed and matched to your system.
I agree it is an odd coincidence, but both conditions (spare and bad sensor in a drive wheel) could be explained by low air temps.
HTH
Edit to add: I was typing while @CharlieS posted so... what he said.
