replacing o2 sensors - question
SF Bay Area
so my '97 has 165k miles on it, and I'm starting to plan some longer trips - many of which are at high altitude and I need all the power I can get.
I've been on a tear lately with making sure the truck is running in tip top shape. I'm not throwing any codes, but lately it has felt a little dull when accelerating, especially uphill.
I ordered a new Fuel Pump Relay so I can keep a spare, as well as a new fuel filter.
The only relevant service record I have is that ONE of the o2 sensors was replaced back in 2012, but I really don't trust the PO's mechanic to pick the correct parts after some of his other work that I've seen.
I'm tempted to just replace all the o2 sensors with Denso units for peace of mind. The prices seem pretty reasonable.
Here's my question:
In all the other threads I see these as the 2 part numbers for a '97:
- 234-4157 is the pre cat sensor
- 234-4153 is the post cat sensor
However, I've also seen mention of a third part number: 234-4520. It seems significantly more expensive than the other 2.
For a '97, do I have 3 sensors? Or just 2? Should I also replace that third sensor?
Finally, am I dumb for doing this as Preventative maintenance if I'm not throwing a code?
your rig have 2 O2 censors upper bank before CAT and lower bank after CAT if they are not Denso consider Denso as most of them do not work well . also consider replacing spark plugs as well ,use OEM with cooper core . That is the minimum that you can do.
Still kind of confused after this... Are there 2 or 3 total?
What is that third part number I listed?
Some autoparts stores have a code reader that you can use at the store that also has the ability to view the waveform from the O2 sensors. The counter guys usually don't know how to use that function, so don't ask them about it, just ask to borrow the reader to check the codes yourself. Then once you're at your vehicle search in the program for real time data, something like that. The engine needs to be warmed up and running to check the waveform. A good sensor will have a quick up and down repeating/regular wave form, a sluggish sensor will have a slower response with a more rounded and changing waveform. Try a search online for images of how they look.
FWIW: My #1 sensor had over 200,000 miles on it and had a sluggish response/waveform, changed it to the correct Denso, got a better textbook image waveform and no codes afterwards, but nothing else changed; same mph(15-16 hwy), same acceleration.
Some autoparts stores have a code reader that you can use at the store that also has the ability to view the waveform from the O2 sensors. The counter guys usually don't know how to use that function, so don't ask them about it, just ask to borrow the reader to check the codes yourself. Then once you're at your vehicle search in the program for real time data, something like that. The engine needs to be warmed up and running to check the waveform. A good sensor will have a quick up and down repeated shark tooth wave form, a sluggish sensor will have a slower response with a more rounded and changing waveform. Try a search online for images of how they look.
Thanks for the advice. I just ordered the two Denso units for peace of mind.
I'll be thrilled if I could get up to 15-16 mpgs. Currently at 13 :rofl:
FYI: the info I posted is not the complete by-the-book FSM test, just something I used to get a quick idea of how the sensors are functioning. There is a specific procedure shown in the FSM.
