Replacing Holley Carb with Aisan
Just north of here
I have a Holley Carb currently on my 1975 FJ40 from the previous owner. I would like to put the Aisan carb back on. I purchased a used carb from pygpen. See here: https://forum.ih8mud.com/showthread.php?t=80658
I plan on rebuilding it then installing it on my Cruiser.
I have seen this article written by rzeppa
http://rzeppa.org/tech/carb.htm
Fuel Hardline
Chock Cable
Throttle Cable
Carb stud
Carb insulator
Carb Insulator gasket
Stock Air Cleaner Housing
Stock Air Filter
I am placing an order, and would like to make sure I am getting everything that I need. Am I missing anything?
Thanks for the help
That sounds about right. Try calling up Mark @ Marks Off Road. He can walk you through pretty much everything you need to know and get you the parts you need.
Good luck!
Make sure you have the proper throttle linkages.
scratch the throttle cable off your list, your 75 will have linkage rods instead. also you want to make sure that you have the original gas pedal, some holley installs used a different pedal made to work with a cable
also you'll need a fuel return hard line, and some vacuum hose
